2023 Tremor 250/350 same truck except for sticker?
timrellis
Lake Elsinore, CA
2024 F250 KR Tremor
Hey all,
Does anyone know if the 2023 F250 and F350 Tremors are going to be mechanically the same? I know the 2020-2022 models were mechanically the same but the GVWR stickers are different. Does anyone know if this will be the case with the 2023’s as well? I have a 250 on order but they just released the towing guide for 23 and it looks like the 250 tremor is 19500 on the fifthwheel and 20000 on the gooseneck. The 350 tremor is listed at 23000 on each the gooseneck and fifthwheel which makes me think there may be some mechanical difference.
Also, does anyone know if you can change your order from a 250 to 350 if the build hasn’t been scheduled yet? I’m contemplating towing a larger toyhauler fifthwheel so if the trucks are mechanically the same I’d be more comfortable toeing the payload line on a 250 but, if there is a difference in actual equipment, maybe it would be in my best interest to have it changed to a tremor 350?
I attached a PDF of the towing guide. Thanks in advance!
Wasn't there a gooseneck rating difference between the 250 and 350 with Tremor for the previous years too? Conventional tow had them both at 15k but gooseneck was....let me look...17,800 F250 and 21,800 F350. Both with a note about a 19k 5th wheel hitch limit. The way that it is worded sounds like they were assuming use of a 5th wheel hitch rated at 19k max.
I'm not sure if that one change in the way they are rating 5th wheel for 2023 points to a physical difference.
That’s a good point. I was just wondering why the 5thwheel and gooseneck would be different (ie. 19.5k vs. 20k) on the f250 but was 23k across the board on the f350. I thought maybe there was some additional frame bracing at the hitch attachment points or such on the f350. Otherwise why wouldn’t it be 20k across the board for the fiver and gooseneck on the f250 if it was just a de-rated situation.
Anyone know if you can change from a 250 to a 350 after the order has been accepted? Still waiting to hear back from my dealer.
I believe you can, but I think it would reset your position in line. But since production hasn’t started, I hardly think this will matter. But I’m not 100% sure. I know in the past, once scheduled, you could change some options, but if you change model or trim, it would boot you from production and you’d have to be scheduled again. I’d just order exactly what you want at this point, and just hold on for the ride.
I think that’s good advice. Waiting to hear back from my dealer still at this point.
Back in 2020 when I ordered mine you could as long as a VIN hadn't been issued. The VIN number 3rd to 6th positions dictate models. I changed from a 250 to 350 after I ordered but before I've VIN had been assigned.
I don't think anyone can verify the 2023 250/350 Tremors are the same as there isn't any in guys hands to compare. The 2020-2022 have been directly compared, side by side to verify similarities.
same for me when I ordered my 22.
