Going to update this with new information. This is what I read, it makes sense, but still it's worth only what you are paying for it.
A well known and reputable engine builder was saying that the worn lifter issue (and I am going to extrapolate other oil related failures) is not unique to Ford but is also occurring in GM and Chrysler engines with the roller lifters. He feels it's totally a lack of proper oiling. With the Godzilla specifically, the oil pump is a variable pressure variety that sees oil pressure drop to about 7 psi at idle. So his hypothesis is this is causing the premature wear in the lifters due to lack of lubrication. Once you get under load, the oil pressure goes way up. He believes that if you change the oil pump to a different kind or change (IIRC, it can be done in forescan) the oil pressure to be at least 15 psi at idle, the problems will go away. At the very least, limit the time spent idling.
