2021 Tremor Carli 2.5" Leveling kit
Carli 2.5 Pintop, Full Deaver, Radius Arms, HIgh/Low Mount Stabilizer. Waiting on the Torsion Sway bar. Looks good on Fuels with 295s for now. Rides amazing. Someone will point out its not a Tremor, Building my own truck, got tired of waiting. Gears, Eaton Front Locker next, then 37s.
What is your caster after the lift?
Your truck is one of my favorites on the site and I have a rapid red on order. I’m probably going to similar mods to mine. Just wondering what type of weight if anything you have towed and how it performed.
8500 empty, bags, like nothing is there.
6.7 and 10 speed is a beast!
looking at these exact wheels again to run a set of 37s
any trimming or other mods (besides suspension) done to get tires to fit without rubbing?
Full lock it barely touches the left radius arm. Then I went and put OEM flaps on. Had to cut the shit out of um, and they still touch under certain flex. Over all, the level rocks and would do it again in a heart beat!
thanks.
is your axle perfectly centered after the track bar install?
mine is still pulled to the driver side a smidge.
i'm looking at the Toyo AT 3 37 which is a touch shorter than the Ridge Grappler 37
thanks.
it was profesionally "aligned" when I did the install. Did get the adjustable track bar, but have to assume it is off at least a little bit. I does not rub on the other side.
