2021 Tremor Carli 2.5" Leveling kit
Good to know when I get mine in! I live off rayford
Call Dana at WPS and she will help you decide the best options for your truck and get things ordered for you.
WPS - Dana
I ordered my Carli suspension, wheels/tires and ADD bumper with BD lights the same week I placed the order for my new truck. I scheduled the suspension to be shipped from CJC to WPS so I did not have it sitting around in my garage. In the end, the truck arrived before all of my Carli parts were shipped to Dana and this was before the severe shortages like we are seeing now. The wheels and tires were at the Tirelink shop in Spring on I-45, and the ADD bumper and BD lights were in my garage with a bunch of other parts I had her install.
The sooner you start the process of ordering the parts, the better chance you will have of getting them by the time your truck arrives. Even with all of my pre-planning and advanced purchasing, it still took almost two months after I received the truck to get everything done just the way I wanted it.
Carli is your best option, but it is not going to be cheap. Here is my Tremor with the Carli Backcountry 2.5" Level kit before I installed my 37s. I have Add-a-Packs in the rear and an additional 1" PMF block under my Add-a-Packs for a total of 2" rake.
did the f250 tremor has the same leaf pack as the f350 correct? (3 leafs and the upper overload)
when you did the add-a-pack, did you do any other modifications to the the leaf pack?
Yes, the F250 Tremor has the same 1-ton leaf pack as the F350 Tremor. The Add-a-Pack sits under the factory leaf pack and replaces the giant factory block. There are no additional modifications to the leaf pack, itself.
Carli is your best option, but it is not going to be cheap. Here is my Tremor with the Carli Backcountry 2.5" Level kit before I installed my 37s. I have Add-a-Packs in the rear and an additional 1" PMF block under my Add-a-Packs for a total of 2" rake. My 7000 lb TT with a 900 lb TW lowered my factory suspension by 1.25", so I am trying to make sure mine will be high enough in the back to avoid sagging beyond level when towing.
I could have driven around with the factory wheels and tires for a couple of months, if I had to, but I already have the new wheels and tires installed.
Now the burning question for me now that time has lapsed
How does it tow with 37s compared to stock.
Do you off road with her?
I'm at the point now of doing a similar setup.
But I tow a lot. My trailer is around 13k and very heavy on the hitch.
I have owned mine for a year and more than 75% of the miles were towing a new 9500+ lb TT with a 1650 lb TW. I never towed with the factory configuration, but it tows great with my Blue Ox WDH, 1500 lb. spring bars and Air Lift 5000 lb Ultimate airbags set at 25 psi.
I have the same hitch setup😀
Do you find 37s to have a lot of sidewall flex?
How about engine/trans temps?
Curious about power delivery with gearing changing so much and tires that heavy.
My trailer was around 1600 on hitch but after some slight remodeling I'm up to 1800 😗
My even bigger concern is going off road. I've maxed out the suspension a few times and I want to keep my mid flaps. My driveway is a 3 mile gravel road.
When towing I air up my tires to 48 rear and 46 front which minimizes the tire flex. The Nittos have a max of 50 psi. The 6.7L has plenty of power to overcome the gear change and additional weight of the tires/wheels.
The 37s were more noticeable and heavy feeling on my Gen 2 Raptor, but hardly make a difference on the Tremor. The 17” wheels give me plenty of small bump compliance when I air down to 38 rear and 40 front while driving empty.
I have not done a lot of off roading, other than a couple of trails while camping in the hill country and I did experience minor rubbing on the inner fender plastic. Others have had success with mud flaps and 37s, but I do not have them on mine.
was just curious, mainly to see where your extra rear height came from. i have an F350, but running a set of F250 leaf springs (non-tremor) with the Carli add-a-pack. I did this because I found a good deal on them and Carli specifically suggests not to use the add-a-pack on the F350 springs. i also have a 1" PMF block
You are correct on their recommendation. I did not want to sacrifice my 1-ton weight carrying capability, so I had the AAPs installed anyway. The AAPs got rid of the giant 3.5" factory block and greatly reduced any chance of axle wrap when towing with 1050 lb/ft of torque.
This was before I installed the Air Lift airbags.
What wheels are these? Also, what offset? Any rubbing?
Rapid Red Tremor
2.5” Carli commuter level.
adjusted air pressures, empty: 50 front, 40 rear.
Method NV 305 HD, 18” x 9. +18
37x12.5x18 Nitto Ridge Grapplers
41 3/8” fenderwell before
43 1/2” fenderwell after.
I am looking to add back my upper overload to my leafs with the AAP.
does that upper overload contact the AAP guide keeper things that have the bolt going through them?
thanks
thanks
When unloaded, the front of the helper leaf does not touch the guides, but the rear is resting on top.
any noises from the rear resting on it? how about when loaded?
No noise at any speed or with loading. I have Ultimate 5000 lb airbags and my truck only squats an inch from an unloaded rake of 2”.
I have not noticed any issues and I specifically asked the installer to leave the overload leafs, as they normally remove them.
One more thing I should mention for those planning to keep their top overload leaf's when using AAPs with the smaller lift. If CJC/Carli sends you the normal U-Bolts for the 3.5" lift, they are not long enough to accommodate the top overload leaf and the associated spacer.
In my case, CJC sent the U-Bolts for the 5.5" lift, so my installer was able to add the 1" PMF block under the AAPs and the overload leaf on top with room to spare. They cut them shorter after everything was done.
The 5.5" lift U-Bolts are longer to allow a 2" block under the AAPs to match the taller coil lift in the front. (As seen in the bottom left of the picture below)
Carli 2.5 Pintop, Full Deaver, Radius Arms, HIgh/Low Mount Stabilizer. Waiting on the Torsion Sway bar. Looks good on Fuels with 295s for now. Rides amazing. Someone will point out its not a Tremor, Building my own truck, got tired of waiting. Gears, Eaton Front Locker next, then 37s.
Rapid Red Tremor
Method NV 305 HD, 18” x 9“, +18
