This bulletin supersedes 21-2049. Reason for update: New Part/Procedure For Same Condition
Model:
Ford
2020 F-Super Duty | Transmission/Transaxle: (10R140) |
Summary
This article supersedes TSB 21-2049 to update the Issue, Action and Service Procedure.
Issue: Some 2020 F-Super Duty vehicles equipped with a 10R140 automatic transmission may exhibit a harsh engagement/harsh shift/delayed shift. It is possible the vehicle may also have an illuminated malfunction indicator lamp (MIL) and diagnostic trouble codes (DTCs) P0729, P0731, P0732, P0733, P0734, P0735, P0736, P076F, P07D9, P07F7, P2700, P2701, P2702, P2703, P2704 and/or P2705 stored in the powertrain control module (PCM) or transmission control module (TCM). This may be due to sticking valves in the main control valve body. To correct the condition, follow the Service Procedure steps to perform the transmission accelerated main control break-in routine for the appropriate clutches and/or overhaul main control valve body.
Action: Follow the Service Procedure steps to correct the condition on vehicles that meet all of the following criteria:
NOTE: Part quantity refers to the number of that service part number required, which may be different than the number of individual pieces. Service part numbers contain 1 piece unless otherwise stated. "As Needed" indicates the part is required but the number may vary or is not a whole number; parts can be billed out as non-whole numbers, including less than 1. "If Needed" indicates the part is not mandatory.
Parts
| Service Part Number | Quantity | Description | |
W712658-S439 | 1 | LPC Retaining Plate Bolt | Package Contains 4 Pieces, 1 Piece Required |
LC3Z-7A008-E | 1 | MCA Separator Plate Kit (Fixed Yoke) | - |
LC3Z-7A008-F | 1 | MCA Separator Plate Kit (Slip Yoke) | - |
LC3Z-7G007-A | 6 | Shift Solenoid Retainers (Small) | Package Contains 1 Piece, 6 Pieces Required |
JM5Z-7G007-A | 1 | Shift Solenoid Retainer (Large) | - |
XT-12-QULV | As Needed | Motorcraft® MERCON® ULV Automatic Transmission Fluid | - |
| Parts To Inspect And Replace Only If Necessary | | | |
LC3Z-7F396-B | If Needed | Fluid Pan Gasket | - |
LC3Z-7G186-A | If Needed | Fluid Filter | - |
LC3Z-7N265-A | If Needed | Main Control Manifold Seal | - |
LC3Z-7N265-B | If Needed | Fluid Pump Gasket | - |
Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Service Part Warranty (SPW)/Special Service Part (SSP)/Extended Service Plan (ESP) coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/SPW/SSP/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
Labor Times
| Description | Operation No. | Time |
| 2020 F-Super Duty 10R140 Transmission: Retrieve DTCs, Check Vehicle Build Date And Overhaul The Main Control Valve Body (Do Not Use With Any Other Labor Operations) | 212317A | 4.5 Hrs. |
| 2020 F-Super Duty 10R140 Transmission: Retrieve DTCs, Check Vehicle Build Date And Perform The Transmission Accelerated Main Control Break-In Routine Repair Complete (Do Not Use With Any Other Labor Operations) | 212317B | 2.0 Hrs. |
| 2020 F-Super Duty 10R140 Transmission: Retrieve DTCs, Check Vehicle Build Date And Perform The Transmission Accelerated Main Control Break-In Routine Overhaul The Main Control Valve Body (Do Not Use With Any Other Labor Operations) | 212317C | 6.1 Hrs. |
Repair/Claim Coding
| Causal Part: | 7A100 |
| Condition Code: | 49 |
Service Procedure
1. Is the vehicle built on or before 10-Feb-2021, equipped with a 6.7L engine and has only DTC P07F6 stored?
(1). Yes - this article does not apply. Refer to other service articles for this condition.
(2). No - proceed to Step 2.
2. Is the vehicle built on or before 01-Apr-2020, equipped with a 6.2L/7.3L engine and has only DTC P07F7 stored?
(2). No - proceed to Step 3.
3. Are any transmission related DTCs present?
(1). Yes - determine the appropriate clutch(s) to be cycled related to DTCs present. Refer to Workshop Manual (WSM), Section 307-01.
(2). No - determine the appropriate clutch(s) to be cycled related to symptoms present. Refer to WSM, Section 307-01.
4. Record and clear all DTCs present before performing the PCM/TCM - Transmission Accelerated Main Control Break In routine.
CAUTION: Failure to use a frame engaging lift could damage the vehicle.
5. Prepare vehicle for the PCM/TCM Transmission Accelerated Main Control Break In routine by positioning on a frame-engaging lift with wheels off the ground to prevent vehicle movement.
6. Using the latest software level of the appropriate Ford diagnostic scan tool, perform the PCM/TCM - Transmission Accelerated Main Control Break In routine 3 times on the appropriate clutch(s) determined to be cycled.
7. Perform the adaptive learning drive cycle. Refer to WSM, Section 307-01.
NOTE: Advise the customer this vehicle is equipped with an adaptive transmission shift strategy which allows the vehicle's computer to learn the transmission's unique parameters and improve shift quality. When the adaptive strategy is reset, the computer will begin a relearning process. This relearning process may result in firmer than normal upshifts and downshifts for several days.
8. Does the vehicle still exhibit the condition after performing the PCM/TCM - Transmission Accelerated Main Control Break In routine and adaptive learning drive cycle?
(1). Yes - overhaul (clean and inspect) the main control valve body. Refer to WSM, Section 307-01.
(2). No - repair is complete.
