Shortly after buying my 2020 Tremor, I put on Toyo MT 35x1250x18 tires, load rating Q128. 34k miles later, I have 2 nails in my passenger rear. Discount Tire says the tire is not fixable since the nails are too close together.
They order me 2 35x1250x18 Toyo MTs but Q123, as the Q128 is on national back order. The Q123 is an E2 (65 PSI) tire, the Q128 is an F2 (80 PSI) tire. They said it should not cause any issues.
Today they put the 2 Q123 tires on the back, and I headed home. Tire pressure at 80 PSI for both tires. On the highway, the truck feels all over the place. Traction control light comes on twice. Heading up a hill, Sway Warning alert comes on, and I can barely keep the truck on the road.
Nurse it home and do some research. The Q123 should not have 80 PSI, it has a max of 65 PSI. I'm thinking having too much pressure in those 2 new back tires is causing the issue? About to go outside and manually air them down.
Bigger problem - the 35x1250x18 Toyo MT Q128 are on national back order
