10 ply vs 12 ply tires
Agreed. The shortage is not their fault, but they should have been more careful with mixing load range on tires, especially a Super Duty truck.
Am very surprised someone screwed up this bad. Poor guy or gal who did this will be going through some additional training. ;)
Glad you got it sorted.
I aired them down to 65 PSI last night, so I can at least drive it for now. Keeping them long term is a no-go since I could never rotate them.
Even after airing them down, driving 50 miles to work this morning, it still felt less stable, especially around corners and on bumpy sections of the road.
Going to call Discount Tire this morning to see what my options are.
You can still rotate front to back what’s the difference if you have both on the front or the back
In my first post, I mentioned these only hold a max of 65 PSI, if I put them on back my TPMS will go off.
Oh gotcha I was assuming you dropped your thresholds like everybody else I never run more than 60-65 psi
I haven't done any Forscan modifications just yet :)
Once you start with Forscan, there are MANY options to be fixed. :)
Annoying beeps, missing numeric readout over gauges, boring splash screen at startup, etc, etc.
I picked up my F250 7.3 Lariat Tremor last Saturday. I did not check the TPMS screen before I left the dealer lot. On Monday, driving to work, the truck "dinged" and the TPMS screen showed both rear tires low at 49 & 50 PSI, respectively. I checked the door tag and it says 60 front/70 rear. Why it took 2 days to register low rear tires is a mystery. I aired both rears to 60 and the TPMS light stayed on for 24 hours and then went out. This morning, it was 36 degrees and both rears showed 57 on the screen, cold PSI, with no TPMS light on. Another member her insisted that the factory TPMS threshold is 10 PSI below recommended but at least on my truck, that does not appear to be the case.
That is an old wife's tail. Had well over a hundred sets of tires from trucks to Porsche's never had a tire that needed "breaking in". Have had some in the past before road force balancing that took several tries on the balancing machine. You are correct that some tires and sometimes specific sizes usually the larger ones can be unstable, been there done that. Air pressure can also be a factor.
Sorry, I read things way too literally...
Shortly after buying my 2020 Tremor, I put on Toyo MT 35x1250x18 tires, load rating Q128. 34k miles later, I have 2 nails in my passenger rear. Discount Tire says the tire is not fixable since the nails are too close together.
They order me 2 35x1250x18 Toyo MTs but Q123, as the Q128 is on national back order. The Q123 is an E2 (65 PSI) tire, the Q128 is an F2 (80 PSI) tire. They said it should not cause any issues.
Today they put the 2 Q123 tires on the back, and I headed home. Tire pressure at 80 PSI for both tires. On the highway, the truck feels all over the place. Traction control light comes on twice. Heading up a hill, Sway Warning alert comes on, and I can barely keep the truck on the road.
Nurse it home and do some research. The Q123 should not have 80 PSI, it has a max of 65 PSI. I'm thinking having too much pressure in those 2 new back tires is causing the issue? About to go outside and manually air them down.
Bigger problem - the 35x1250x18 Toyo MT Q128 are on national back order :(
I’m still running stock tires. Although I used Forscan to reset the psi for front and rears. Now running 65 rear and 50 front. Much better ride when not towing. You could do as some said and rotate the tires and use Forscan to allow for lower PSI so your truck doesn’t like up like a Christmas tree.
It’s more like 20 psi threshold from my experience. I have my rears set to 60psi and can run the sticker 80 or 40 when off road with no warnings. Also our 2020 F 250 Tremor has 60/80 psi front and rear. Wonder why it’s been changed to 70 rear now.
Haven’t come across a manufacturer or business in quite sometime that doesn’t say it’s fine, doesn’t matter or normal when they want to give you an inferior product or something isn’t working. Sounds like if they over pressured them it would be on them to replace them. Naturally they will say they do it all the time it doesn’t matter. Like the ford dealer that told me they reuse torque to yield bolts all the time, and then later trying to justify what they told me said oh the reason ford says don’t reuse them is because they come from the factory with loctite 🤣
I think tire pressure in the rear tires is 80 and in the front tires it’s 60 at least it is on my Tremor 7.3 MY 2020. Maybe they should move the Q128’s to the rear of the vehicle and Q123 to the front axle
I think tire pressure in the rear tires is 80 and in the front tires it’s 60 at least it is on my Tremor 7.3 MY 2020. Maybe they should move the Q128’s to the rear of the vehicle and Q123 to the front axle. The rears will carry most of the load. i Have my rears aired down to 75 psi and they are all nitrogen filled including my spare
Put sticky plugs in the holes Discount tire has to worry about liability plugs work great even the harbor freight and walmart plugs
The 60/80 psi is the pressure for max load I run 50/45. Rides better I did the chalk test and they are wearing even
I don't know about the 7.3, but in the 6.7 it is 80 is the front and 60 in the back. I assume because of the engine weight.
I think you might have that backwards for the 6.7L. Lots of pictures of people's door stickers in the thread I linked below showing 60 PSI for the front and 80 PSI for the rear for diesels.
(They posted them for the purposes of payload capacity, but also shows tire pressure.)
