Yaesu FTM-500 UHF VHF Ham Radio Installation
Finally finished my Yaesu FTM-500 UHF VHF Radio installation.
For reference I used the following items:
  • Yaesu FTM-500DR Radio (dah)
  • BuiltRight Industries Dash Mount
  • BuiltRight Industries Rear Seat Back Storage Panel (Passenger Side)
  • Bullet Proof Diesel 3rd Brake Light Dual Antenna Mount
  • Various cables and parts from Amazon
  • 3D printed Mic holder and 3M VHB tape
The control head and mic are connected with 2 separate shielded Category 6 ethernet patch cables. The control head cable works without any modification, but I used an ethernet passthrough in the dash to have the ability to unplug it from the control head and not have any wires showing. The mic cable I have connected to an ethernet passtrough in the center console and another ethernet passthrough near the main radio that is connected to a custom RJ12 to RJ12 short, flat cable. Only 6 pins are needed for the mic and it has an RJ12 connector in the radio for an extra mic.
I like this installation because the speaker in the FTM-500 control head is more than enough for my old ears to hear with. I also like the fact that the main radio is out of sight and I can remove and hide the control head easy when I'm parking. The mic mounted near the drivers leg keeps the mic out of the way and the emtpy spot on the dash between the 4-wheel drive selector and the radio volume fits the mic mount perfectly.
This was not a cheap installation, but I love how clean and organized it is.
Hopefully this helps or at least gives you some ideas of your own.
If you're into 3D Printing the mic holder can be found here (not my design):
Cheers!
This is a fantastic install and, I agree, not a cheap one. I also have an FTM-500DR in my F-250 Platinum but went about it a different way. My radio body is mounted under my driver seat and I created a custom mount for the control head on my center console.
I already have too many things up at eye level with my RV GPS and my Tire Pressure Monitor display for my trailer so I didn't want it up there on my Built Right mount.
Also, by putting it under the driver seat I can actually balance the audio from the main unit to the control head.
I especially like the Bullet Proof Diesel antenna mounts you have. I would like to do that but I have a cap on my truck and don't want to go through all that taking it off and installing it so I have a Comet mount that uses a bolt under the hood and allows you to mount the antenna on the driver's side without touching the paint. That way I can use a longer antenna (I run a Diamon Super Gainer) and still get in the garage.
Again, awesome install! I will post some pics of mine soon.
Cheers and 73!
de AF1US (Brian)
Cheers and 73!
de AF1US (Brian)
I really wanted the 500 as well but like you, I did not want it above the screen because of having other items there and due to theft. I mounted my FTM300DR inside the sunglasses holder which has its benefits and downsides. I tried to see if I could mount the FTM500 up there or down where the wireless charging is but it would not fit in those places due to the thickness.
Came out nice! Reminds me of my install for my FTM-400. :)
Nice Install, I have the TYT-9800 in my truck.
Cheers and 73!
de AF1US (Brian)
I definitely want to see what you came up with.
Cheers!
What did you use to attach the Yaesu front-end to the BuildRight Dash Mount? Did you use the Mountech Phone Mound Bundle? If so, which arm length would you recommend? Looks like a nice install.
Cheers!
This is the best install for this I have seen yet. I have the same radio and am about to do something very similar so thank you for the inspiration! Can you share the parts you used for the fuse sub-panel? I know I need the BuiltRight panel for behind the rear seat, but how did you run the power wires to it? I like this idea because I have 3 things I want to power and this way you only have to penetrate the cab once.
I ran mine through the cableway on the driver side under the door and through the nipple behind the brake pedal to the battery. Works great!
Did you also do a fuse panel behind the rear seat?
Can't recall. Probably either 8 or 10 ga. Having extra copper never hurts.
I want to power the same radio (FTM-500DR) as well as a compact CB and Starlink Mini, but I want the CB and Mini on two upfitter switches. The CB a Cobra 75 All Road, which has the mic as Bluetooth and you power it from any USB port. It says you can turn it on and off from the wireless mic but that means the base unit has to draw power to take that Bluetooth power command. I need to remove power from that when not in use. Same with Starlink, I want to flip it on and off as needed.
My issue is that I don't think a rear fuse panel is ideal for this as I will need additional wires to use the upfitter switches, and power would have a route twice as long and drop voltage. So I guess I need to run 10-12 gauge wires for the Yaesu, and a 4-conductor 16 gauge for the other two devices. Does that seem right?
I would run power from the battery to the fuse block. Run your uplifter switch wires to relays that drive your equipment from the power supplied by the fuse block.
Hadn't thought of that! Do you know of any relays that handle that amount of power?
Google, or do a search on Amazon for, “12-Volt Solid State Relay.” There are literally thousands of options to choose from. Select one that satisfies your mounting and ampere requirements. Be sure to select a relay that will operate using the power provided from the uplifter switch.
