Yes I can hear the pump. Thinking it’s a disconnected line or something.Can you hear anything when you hit the button? may be a disconnected wire/plug or a kinked hose.
That’s what I figure. Going to have a look and see if it’s an obvious dissconnectKinked hose or disconnected hose is the likely suspect. The motor can die too but that's rare. is there a puddle of fluid under your truck?
That’s what I was hoping to hear. I will have a look and see if that’s what it is. Has the problem reoccurred? Did the line stay connected when you put it back on?I had the line that comes off the reservoir pop off in 2 places.
No it hasn't happened again. I just don't think it was seated all the way from the factory.That’s what I was hoping to hear. I will have a look and see if that’s what it is. Has the problem reoccurred? Did the line stay connected when you put it back on?
