Wheel Load Ratings
Gilly
Tremor Buff
Albuquerque N.M.
F150 Ecoboost FX4
I tried but I just don't like the looks of 2023 Tremor wheels. Interested in the Fuel Beast wheels. Want to keep the same offset and tire size. Will the load rating be the same or less?
It doesn't look like that wheel comes in the same width and offset as the stock wheel. If the Ford wheel load ratings are the same as previous years, then that Fuel wheel has a load rating 90lbs less than the stock wheel.
Thanks StrokinOut. What size do you think is closest? 18x9 1 offset?
The stock wheel is an 18×8 with +40 offset. I only saw 1 option in that Fuel wheel with the SD bolt patern. The 18x9 1 offset.
As you can tell I don't have much knowledge about offset. +40 vs 1
Does that mean the tire will extend out further from the wheel well? If so how much? 39mm?
The more negative you go, the more it will stick out past the fender. If you stay with a positive offset, you should be able to find something that stays pretty tucked under the fenders.
I used one online calculator that said it would sit out 52mm more than the stock wheel. Some of that is from the additional wheel width. Not sure how accurate that is, but less positive offset does move the wheel outward.
Hmmm, I really like those wheels but I don't want a mud slinger.
