What shocks? Need part numbers for stock Tremor
His words:
"If your vehicle is stock ride height and you plan to keep it that way, we would highly recommend our B6 4600 series. They are considered by most to be an upgrade in comfort and performance over the OEM system and provide superior handling and control when towing. At stock ride height they are our best riding and longest lasting damper. There is a lot of misinformation online that suggests our 5100 series is stronger, better or more heavy duty than our 4600 series. Nothing could be further from the truth. Both are made out of the same high-quality materials; the biggest difference is the coating and the fact that the 5100 is physically longer as it is intended for a lifted application."
Yes I’ve always been told the 5100 series are for lifted and leveled trucks. I had a set of 4600 shocks before they were great for what they were
These appear to be a size up from standard for trucks with a 2-2.5” lift. The standard 5100s work better I believe for the tremor application due to the stock factory ride height increase. Am I wrong?
Those are the shortest 5100's they have for the Super Duty. What standard 5100's are you talking about? Don't let the "2-2.5" description throw you off, those exact 5100's are a popular choice for use on stock non Tremors without any issues. The fronts are no more than 3/4" longer than the stock non Tremor shocks.
From Bilsteins website B8 5100s
24-274951 Front with Tremor Package 0-2"
24-274968 Rear 0-1"
33-206254 Rear 1.5-3"
Does the Tremor have any sort of lift from the factory? or would the 0-1" be whats needed?
24-274968 Rear 0-1"
Here is one way to look at it...the Tremor uses the same rear block as the 2017-2019 Super Duty, and the same leaf pack as a non Tremor. That 24-274968 rear shock includes 17-19 SD with 0-1" lift in it's fitment. Does the Tremor have any additional lift in the rear compared to the 17-19, not that I'm aware of. Also, that same rear shock includes the 2020-2022 in its application, which has a 1" shorter block than the Tremor and the 17-19 SD, so would it not be good for 0-2" lift on a 20-22 non Tremor?... Bilstien isn't the greatest when it comes to these application specific shocks, they create confusion.
That 24-274951 front shock is another good example of that. Fitment says 2-2.5" lift on 17-22 non Tremor but 0-2" on a Tremor, wtf lol.
Anyway, my preference is to go by measurement and knowing what travel limitations I am working with. I think the 24-274968 would be the correct shock on the rear of a stock Tremor.
Got mine replaced by the dealer. Truck does ride quieter and smoother.
Happy to hear you got yours replaced.
I'm not bothering with replacing the stock crap. It's not worth the effort. The dealer won't order until they diagnose and they won't make an appointment to do work, only to drop off.
