What Milage should i do a Tire Rotation for the first time?
I appreciate your experience, but the point of regular rotations is to avoid irregular tire wear - not to spot it after it happens.
No one is going to notice a tire that is 2/32nds more worn than the other 3. Not from a mile away, not in their sleep.. not up close and personal without calipers.
As an engineer and truck enthusiast I am keen to follow the industry standard known best practices on my vehicle, but absolutely respect those that prefer to follow their own path.
I also do oil changes and other service tasks on my Toyotas at twice the recommended frequency, but that's because they are very abused.
I know most don't have my skill set but that wasn't the OP's question. He asked what we practiced. That's what I stated. You took me to task for what I stated I practice. BTW, I'm a machinist by trade and can tell by sight and feel if two items are different in thickness by as few as .005". I don't expect the average to do that, but I can. And I can determine tire wear literally with my eyes closed. Forgive me for my habit for hyperbole. Again, I'm used to getting far more than the warranty mileage out of a set and I never drive on tires under 3/32".
BTW I'm that guy at work that the engineers come to in private for ideas and advice.
For the Diesel the manual states that tires should be rotated at every oil change. And that oil changes intervals will be indicated by the dash information center (pg 564). I have mixed feelings about that as a good system. On one hand the oil life sensor should be a good indication of how severe the vehicle has been driven. On the other the need to conduct maintenance on a regular schedule is important. The manual goes into when you should expect the light to come on. It states that this interval could be anywhere from 2,500 to 10,000 miles depending on use (pg 561).
So if I drive the shit out of my truck and have to do maintenance at 2,500 (based on the oil life sensor) then the next interval I take it easy and make it to 10,000 and repeat that cycle, the same tires will always be on the front of the vehicle during the severe use part of the cycle.
For the gas motor it just says do maintenance every 10,000 miles.
Here is what the tire rotation pattern is for our trucks:
I only have 2000 Miles on the truck but have already had to have one tire replaced due to a bulge in the sidewall! I want to make sure I rotate them as I have seen what the larger tires will do to themselves and the suspension if not.
Funny you say that, I had mine in for 5k service and they tell me I have one tire with a bubble on the inside sidewall. I haven't even looked I was so mad. 5k miles and I need to buy a new tire. It sounds like a tire defect to me
Thank you for all your reply's! I believe I will stick to the 3-5000 mile rule. The issue with the bad tire was a bubble in the sidewall. the truck vibrated over 50 MPH. Not sure how it got thru inspection when the wheels were spun and weighted?
