I got a Bulletproof hitch with the anti rattle on my Ram 3500. Mine is the 22,000lb conventional rated. They have an extreme duty 36,000lb conventional as well.
2.5
Our 2.5" Heavy Duty 6" Drop & Rise Hitch is unlike any of our competitors. We worked hard to create one amazing Hitch that does the work of 10. Our hitches are extensively tested and exceed SAE-J684 testing requirements. They are built with such high standards that we have never had a single...www.bulletproofhitches.com
I went with B&W 2.5”/7”… probably more than I will ever need.
I don’t think it’s too long at all. I probably have at least 12” from the end of the hitch to the ground. I would say if you plan on 2.5” of lift and 2” taller tires I think you may even go with the 9” B&W. If you can hold off buying it until you do your mods I would wait. I can take a pic tomorrow with a tape measure and post it if that helps.At the moment, in stock form, I feel like the 7" might be a tad long for this truck, maybe hangs a touch too low, but I am hoping that after I install the Carli 2.5 and 37's it'll be just about perfect for it. Thoughts since you're using the same one?
Sorry for the late answer. Nope 5500lbs plus gas, plus life jackets rope, anchor, and other stuff we leave in the boat.Does your boat weight of 5500# include 92 falllns of fuel?
Just picked up the 6 inch drop medium duty. Built like a tank, don't throw your back out lift it lol. I spent way to much time measuring hitches before I decided on their 6 inch drop. I tow a wide variety of trailers...Any thoughts on the Bullet Proof Hitches![]()
