Featured
- #21
I’ve been under my truck a bunch and didn’t notice any grease Zerks. Guess my brain just assumed it wouldn’t have any.
Ya I think it's a commonly missed thing. There's one on each side in the universal joint for the front axles. They're tucked up in there a bit, so you might need to rotate the front hub by hand to be able to see them.I’ve been under my truck a bunch and didn’t notice any grease Zerks. Guess my brain just assumed it wouldn’t have any.
Yeah, kind of a feature. The company makes some best in class greases.
Good to know, I'll have to check them out. I hate my current grease gun. That lock and lube is awesome btw, well worth the $20 or so it costs.Another good run down of different grease types from the maker of Lube Shuttle:
I’ve been a Messicks YouTube subscriber for years now - love Neal’s content!
Well dang it. I've watched some videos on the Lube Shuttle and I think I'm taking a trip to Home Depot to return the Ryobi gun. That really is slick.I have the Dewalt (virtually identical to the Ryobi.)
Works well, but kind of messy, and a PITA when you need to use multiple types of greases.
Only concern is none of their greases have a dropping point that matches or exceeds the Motorcraft one, but I'm pretty sure the majority of Super Duty owners are just using a generic high temperature grease.
If you go with Shuttle Lube which grease do you think you would use on the Super Duty?
That's the exact conclusion I was just coming to lol. Found this video which does a fantastic job of explaining the different greases they offer and what they are good for:Good question. I might be inclined to use LI400 as it is the “spend money to not think about it” option.
I’d also bet that the Germans conservatively rate their greases…
That said, I’ve read on other forums that even XG11 is way overkill for the front of these trucks.
But I’m no mechanic, hence, happy to spend money to not think too hard about it.
Ok, here's the kit I'm probably going to get: https://advancedenginetech.com/product/lube-shuttle-travel_trailer_greasing_kit/Good question. I might be inclined to use LI400 as it is the “spend money to not think about it” option.
Wanting to pick up grease so I can keep on top of the grease zerks in the front end of the truck. Curious what y'all are using and prefer.
I plan on greasing them every oil change...so basically a regular service interval? And I plan on doing the routine servicing myself, which means I'll need the stuff to do so.Color me stupid as this is all new to me, why do you need to grease the front end outside of regular service intervals?
Yep! Definitely different beasts. All sealed bearings on the F-150.Gotcha, that makes total sense, heck, I just learned they do not have “A” on the 4x4 knob even thou they have the same transmission as the F150
Lots to learn about thr Super Duties compared to the F150
And as a heads up, the F-150 and Super Duty have quite different transmissions. While they are both 10 speeds, the Super Duty transmissions are far more robust to be able to handle the torque of the PowerStroke. While I'm sure they took learnings from the F-150 transmission, since it came out first, Ford states there's no shared parts between the two.
I suspect that's also part of the reason for the lack of auto 4x4: being able to handle the torque of the PowerStroke in the transfer case.
I love the LocknLube locking coupler. Working with heavy equipment greasing daily is mandatory and it makes a huge difference. Plus when it wears out they sell rebuild kits for cheap and in 10 minutes it’s like new again. I have it on my Milwaukee M18 grease gun and won’t have another grease gun without it.Good to know, I'll have to check them out. I hate my current grease gun. That lock and lube is awesome btw, well worth the $20 or so it costs.
This thread has convinced me to get the shuttle kit with the Li400 grease. I’ve never had to grease anything before, is there a process for removing the old grease or do I push this Li400 in at regular intervals and allow it to initially mix with but eventually over time displace the factory grease?
Replace factory installed joint with a brand new one. Guaranteed no old grease in it then!This thread has convinced me to get the shuttle kit with the Li400 grease. I’ve never had to grease anything before, is there a process for removing the old grease or do I push this Li400 in at regular intervals and allow it to initially mix with but eventually over time displace the factory grease?
