Welding newb - sizing a small wooden fence steel frame
Mattlikesbikes
Austin TX
2022 6.7 Lariat Tremor
Just started with my cheap flux core welder and am making functional welds (nothing I would risk my life on, but well enough for ranch fixes).
I am just finishing a small privacy fence rebuild and need to add a gate - 36" wide and 6" tall. Using cedar pickets (6'x5.5"x.75" though I can plane them down to be lighter). I want to weld up a small metal frame so I don't have to worry about the sag from wood or weight. Also, I have now obtained the ability to manipulate metal, so lets put it to use.
1" square tube seems kinda big for the job, but 1/2" seems small. I am sure the 1/2 is strong enough, but might make picket mounting difficult. so 3/4" or 1" - Which is going to be enough without being too much?
I see these youtube videos where they are triming out a wedge from square tube then bending it to a 90 and welding, so no end caps and 3 sides of welds. seems simple enough, but is it too complex to tackle as an early project? And lastly, if I get good enough penetration can I grind off the ugly?
Use at least 1 1/2" sq tubing if you're putting pickets on it. Do one 45 brace corner to corner. And sure you can grind off the ugly welds. Use thin gauge tubing, it doesn't need to be heavy. Just one persons opinion.
...is it too complex to tackle as an early project? And lastly, if I get good enough penetration can I grind off the ugly?
Only you can determine if it's too complex. I say go for it. Get some extra square stock and make some test pieces.
As far as grinding.. grind away. I'm admittedly terrible w/a welder but a pro w/a grinder. Good penetration is good penetration. Visible surfaces are often ground perfectly smooth, and then filled and painted.
