WANTED WeBoost antenna mount
AZsurveyor
Tremor Maniac
Founding Member 📜
Meetup Organizer 🌵
Phoenix, Arizona
2022 F350 KR TREMOR RAPID RED 6.7L
2007 F350 KR CC 4x4 LB
This may be a long shot but if any of you have a weBoost antenna mount that you no longer need or want, I am in need of one.
As pictured below, mine is injured with only one dowel pin for the knob locking purpose.
I tried to remove the good pin to replace the broken dowel but was unable to. These must be driven in and I'm afraid to cause more damage should I put more force in attempting to remove it.
For now, it is working but I can see the excessive waving of the antenna while on the road, leading to the fracture of these dowel pins.
I am using a quick release which is potentially adding more stress and weight to the antenna causing the fracture of the dowel pin.
I do know that weBoost sells the mount and hardware separately but inquiring here first before I drop $$$ :sneaky:
