Water intrusion - where to start?
Holy hell!!! That’s how you found it?
Wait - am I seeing that right? the plastic does not even look like it is correct at all. Should be covering the entire opening
Correct, that's how it was when I pulled off the door panel. And took absolutely no effort to pull the rest of the way off.
What I've done on several of mine is carefully pull the plastic from the door and remove all butyl tape. I put new butyl along the door metal opening, especially along the bottom (so there is no pocket for the water to sit between the metal door and plastic) I usually put a second row along the bottom as well. Maybe overkill but really not much extra time to do it. When applying the plastic, go slow and even. I go from the bottom towards the top to ensure the bottom is as smooth as possible and does not "pucker".
good luck
Is this the factory butyl tape (image below)? I thought it was more of an "adhesive" sealant. Would you recommend i try to remove all of this so it sits flush?
Unreal. Did you buy the truck new? Seems to me that someone was already in there
Yep. Ordered it and had about a 3 month delay from build date to delivery. Bumper to bumper warranty expired in March but didn't have this issue pop up until the last week.
I may be wrong here, but I don't think that plastic skin is the correct one for your truck. Why would there be Butyl tape across the opening in the door.
It doesn't fit the opening. My 2019 (non-Tremor F350) and 2024 F250 skins completely cover the opening (as seen in the first video clip I posted)
Someone just slapped whatever over that hole and prayed.
In the mean time, just ensure there is no "bunching" or "puckering" of the plastic and really press the Butyl into the metal door.
On closer inspection of your picture of your inner door, maybe the entire plastic shield detached and slid down and that's why it looks so wrong/off?
It was slid down. Not even close to in position and not a bit of it was actually stuck with the adhesive.
