Found this very informational article on this topic:
description why part time 4WD can not be used on dry high traction surfaces like asphalt tarmac
www.4x4abc.com
When starting from a standstill with sharply turned wheels: The need for higher rpm in the front will most likely prevent you from getting started at all. If you step on the gas really hard (plus slipping your clutch) you might get the vehicle moving with spinning rear wheels but stress on all driveline components will be dangerously high. Chance is that you will break something.
