Unknown knocking sound from under bed
I have an appointment to go in and have the noise inspected as well. I asked how long new shocks will take to get in and they said a week. Kinda annoying honestly. Truck has just over 5k mi and shocks are already bad. I know they are free but my drive out to the dealer isn't free... Especially with fuel cost... And I have to make the trip multiple times because parts aren't in stock
Same noise here with 5,000 miles. Bet it is the shocks also.
I've had my 2022 F250 7.3 Tremor for about 6 weeks now and I've noticed a knocking sound from under the truck since purchase. I can hear it from inside the cab when driving at lower speeds, but is hard to hear once road noise takes over above 30mph.
It happens on/off throttle, on/off brakes, and just takes very slight movement (bumps/road imperfections) to hear it knock. Sounds like something solid hitting the underside of the bed.
I can get under the truck and push up/down on the truck to replicate the noise. Definitely seems to be coming from under the bed, but I can't pinpoint it. Not the spare tire, not the exhaust, and doesn't seem to be the bed contacting the cab.
Has anyone else encountered this? I plan to make an appointment with the dealer, but I don't have a lot of confidence they'll put the effort into finding it. Thanks!
Hey and good morning from Des Moines, Iowa....
Yes...
I've notices a noise from like three front left corner of the bos...boss....
Luke when I hit a bump it's like a loose somthing which I cannot replicate either...
It is usually around 30 to 50mph when I notice it.?n
I hope is nothing to hurt anything....
Very mechanically loose....
I would grab the "free shocks" and order online after market FOX or I'm looking at a shock system from CJC OFFROAD...
They're not cheap and come with whatever gear you want ... like shock system... You'll be able to go 65mph on a rough surface and it smooths out electronically with a computer....
My tremor is an F350...
It rides very rough....
I'm considering the upgrade...
It is pretty expensive, but touches on several bad characteristics these Superduties have...
Yeah, my next thought was also suspension related. Either something loose or binding/rubbing of some sort. Just tough to inspect thoroughly by myself (I've got street parking and no driveway). I'll probably setup an appoint with the dealer for next week and get it on record in case an issue arises later
I just came from the dealer today with the same issue for my 22 F150 tremor and they don’t know what the issue is but they clearly have the noise they have to wait for Ford motor corporation to tell them how to handle the issue
Welcome to the forum! :)
Took my 22 Tremor with 6,000 to dealership for rattle somewhere under bed. Bingo, new rear shocks fixed problem. Is this an special made shock by Ford/Motorcraft or is it an outside vendor?
Interestingly enough, there is a thread elsewhere on these boards entitled "Tremor Shocks Suck"!!
