Tremor aftermarket wheels & tires 37”
To anyone with 37's or bigger. Did your gas mileage change from the factory 35's? Up or down?
I had to install spacers in the rear only 5/8”
I also had to customize the back of the center cap.
What brand spacer did you go with? Did you have to trim the bolts? I was told anything under 2” spacer requires trimming the bolts. Lastly, did this fix the front and rear width difference (given that stock rear is narrower than front/Ackerman design)? I have the ReadyLift 2.5” installed. Will likely go with Method 305 20” with Toyo ATIII 37x12.5. Sorry for all of the questions. You’re one of the few that corrected for rear being more narrow than the front and I’m planning to do the same.
