- Jul 16, 2021
- 269
- 798
- 2021 Ford F-250 Lariat 7.3L w/ Tremor & Blackout Packages
- 2017 Polaris General 4-Seater w/ Tailpipe Turbo
Decided to pay the local Ford dealership $365+ tax to flush the transmission (and change filter) in our 2021 F250 Tremor w/ 7.3L gas motor at only 13k miles. As a side note, I haven't allowed anyone to perform maintenance services on our vehicles in the last 10 years due to poor workmanship experiences. I once again regretted this decision as I noticed the transmission was leaking fluid on our garage floor the next day and several bolts were so loose on the plastic transmission pan that I could spin them by hand and see a gap between the pan and the mating surface of the transmission. I of course took pictures, forwarded them to the service manager, properly torqued the bolts in sequence myself, and so far no leaks, so I do not believe they ruined the transmission pan gasket as well. But with the known CDF clutch hub design defect and the transmission fluid temperature reaching 240 deg F three camping seasons in a row when towing uphill (~100 def F outside temperatures), I didn't want to give the dealership (or Ford) the opportunity to point fingers when this transmission eventually fails from excessive temperature cycling in the future. But I wanted to kindly post the results of the initial baseline for the Mercon ULV transmission fluid that was changed out at only 13k miles. Results were actually better than I expected.
