I guess I look at the desire for the larger tank differently than some. I want it and I'm going to get it simply because it's convenient and I want it. Need is secondary until the price becomes prohibitive. I didn't "Need" a $75K+ Tremor. A $40K F250 XL or XLT would have probably served my needs. I didn't "Need" several of the other Mods that I have on the truck. If we are going strictly on need, the majority of the Mods owners are putting on their trucks would go away. The argument that certain high dollar Mods are "Needs" is usually just a rationalization to get a mod you desire, not really "Need". I personally don't understand the need or desire for a $5K installed Carli Pintop System, but hey, to each their own and happy trails.
For sure. I was (am) just generally interested in anyone that had an actual need for one.
Last year wasted half a day on elk hunt to get gas and half day on Mule Deer hunt to get gas...NR tags are not cheap..I want to spend 100% of daylight trying to fill that tag not getting gas. Doesn't take more than a year of eating 1k elk tags to realize I need a bigger tank....I like to go way out for relaxation/vacation coming back into town is a PIA.
That would suck for sure. Sounds like the added range may even basically pay for itself in meat! I wish I could get anywhere near that for any remotely probable calculation and I'd go for it. The convenience would be really significant. Just can't get there on the value proposition though. Really wish I could; definitely bummed to pass on it.
100%. I was prepared for $2,000 installed. I'd be interested to hear someone's rationale for "needing" it. We put on 30,000 miles a year driving all over North America with our Airstream. It would be super nice and incredibly convenient, but we definitely don't need it. I guess if you were doing hot shot runs... but then why aren't you in a diesel to start with at that point?
Just cuz you can not afford it does not mean I have to justify my purchases to you
It’s a slippery slope having to justify why you need something while the pours say they can’t justify purchasing it
Who said anything about justifying anything to anyone? I was just curious if anyone had a genuine use case that extended past the basic want or worth it proposition. The above messages about hunting definitely make sense and was interesting to learn and not something I’d thought of. There are probably others, and again… genuinely interested. It has zero to do with raw dollar cost. The value just isn’t there for me, so I’m not getting one. Sounds like the value is there for you and that’s great. You’ll love the range, no doubt.
Perhaps similarly, we (wife and I) have several bicycles that cost significantly more than most people would think rational to spend on something without a motor. Maybe you wouldn’t choose to spend your money that way. Doesn’t mean it’s not the right choice for me. Anyway, still generally curious for the use cases beyond the convenience of range.
Oh and to respond to your other message about cost of reprogramming. The basic forscan license should cover it so shouldn’t cost you anything. If you have a dealer do it they usually charge $50-$100 per reprogram based on what I’ve seen.
You implied needing to justify it but feel free to pretend you never ment what you implied
I have foreskin and use it in plain english and do not screw around with the other side of it
One more quick question on this tank. Do you have any problems with the high-speed filling stations (for big rigs) constantly shutting off when filling this tank? I am towing a 42' fifth wheel, so my configuration does not fit in normal gas stations. (Which is another big reason to buy one this tank to allow me more time to find the right-size filling station while traveling) :cool:
Filling at the big rig pump - nozel fits in, but it is an art form to get it to pump and not shut off - you can't go full tilt on fueling, it just can't handle the flow rate and it will click off - you have to slow the flow a bit at the handle - but still faster than most regular pumps
Ok, that is what I read on another forum. I talked to a local installer in my area, and he said the S&B has two relief valves at the top, but they are connected together for some reason. He also mentioned they do not have internal baffles like the factory tanks which also contributes to the high flow-rate issues.
He said the Transfer Flow tank is the only one with baffles and what he called “correctly“ located and routed relief valves to allow you to use high flow diesel truck stops at full speed when filling up. Of course, the TF aluminized steel tanks cost $1000 more than the S&B and Titan plastic tanks, but in this case, you get a better design.
Ok, that is what I read on another forum. I talked to a local installer in my area and he said the S&B has two relief valves at the top, but they are connected together for some reason. He also mentioned they do not have internal baffles like the factory tanks which also contributes to the high flow rate issues.
He said the Transfer Flow tank is the only one with baffles and what he called “correctly“ located and routed relief valves to allow you to use high flow diesel truck stops at full speed when filling up. Of course, the TF tanks cost $1000 more than the S&B and Titan plastic tanks, but in this case you get a better design.
I have had transfer flow tanks in 3 prior trucks and always been happy with them. They offer good product!
It's been a while since I've been around, had a bit of an extended adventure that afforded me an opportunity to experience significant hardship - I'll post about at a later time but... Reading through this thread is a bit confusing to me.
The bottom line is that due to our petition, TransferFlow agreed to go through the development process in order to make what is essentially a limited run forum tank. They developed it because we demonstrated that there was a sufficient number of us to make the R&D and certification process worthwhile. Literally no one else in the industry was willing to give us the time of day, except this company.
The reason I point this out is that people seem to have lost their shit regarding the price, and I agree, $2800 sucks... BUT the fact remains that the reason other tanks are $1300 are their economies of scale. Were there a large market segment that justified the mass production of these tanks then over time the price would fall in line with the expectations of many on this board. But in this instance, that's just not going to happen anytime soon. That shit $2800 price is much higher than a comparable diesel models because it's a product virtually no one wants and TransferFlow has to pay for their sunk costs.
So no, it's asinine to expect TransferFlow to do a group buy at a significant percentage discount because what people fail to grasp is that the $2800 price essentially IS the group buy price; we are the group that is consuming this limited first run of 300 tanks. WE are the group they made it for.
Now, I never got a number, and no one reached out to me from TransferFlow despite my participation from the beginning BUT assuming I've got my preorder place all lined up, I'm going to buy. Everything around us is going to shit. Parts and supply chains are being choked to death, on the daily, for 'reasons'. Even Ford OEM stocked parts are becoming a dry well. But here's a company that in the midst of these material shortages, chose to respond to a small subset - of a single enthusiast forum - that petitioned them to make a specialty niche product.
In my experience, that does not happen frequently.
I'm not say we owe anyone anything, it's not like that. I'm saying that in a drawn contrast with most other manufacturers at the moment, TransferFlow did something rather substantial for us and I'm grateful for it. I want the tank and I want to support manufacturers who engage with small communities.
Also my gas mileage sucks, so having the additional range would be invaluable.
I'm just saying, I'm grateful.
It's been a while since I've been around, had a bit of an extended adventure that afforded me an opportunity to experience significant hardship - that I'll post about at a later time but... Reading through this thread is a bit confusing.
Also my gas mileage truly sucks, so having the additional range would be invaluable.
Yes, we have not seen you around for a while...
The other big difference with TF vs the others, is they use aluminized steel which has higher cost than a polymer tank. They also have designed it with baffles to prevent sloshing and proper venting to make it easier to fill at higher speeds. I realize high-speed filling does not pertain to the gasser option, but they seem to take the small details into mind when building their well-constructed tanks.
I do not know you, but right now just from reading this you and I are of the same mind. I want the tank because I drive to CA a lot for family and it will pay itself. However if I tell someone I will do something I will do it. When I get the call/email I will order.
I guess let me throw out another point. The first post of this thread states the price should be around $2000 and that was in Jan or this year. That is a 40% from projected price. I work in Aerospace where designing a new aircraft and components for said aircraft takes over 5 years. At the beginning of this cycle we have to estimate the cost of said make believe parts. If we came back in 8 months and said "sorry, price is 40% more", then I guarantee they would back out or flat out not pay.
Saying we are the only ones changing our minds by backing out of a forum agreement seems a bit one sided.
$2000 already seems higher then the other tanks on the market for the reasons you said above. $2800 seems out of line.
I have to agree with you 100%. Operating in one of the most regulated industries, and at this time an industry that is teetering on total collapse, I'm actually astonished TF decided to take this on. Moreover that they were able to pull it off in the relatively short amount of time they did.
I realize many of those that were initially taken by the possibility that a tank was actually going to be produced, didn't realize the development costs would have to be recovered from the get go. This market could and probably will dry up quickly considering the difficulty Ford is having producing trucks all together. And there's always the possibility that Ford has picked up on the desire for larger tanks in the short bed super duties and may upsize the standard tank, which would also reduce demand for an aftermarket tank.
I'm grateful there are still companies that live up to their word, especially in difficult times. 🍻
I never said that that 'we are the only ones changing our minds by backing out of a forum agreement'.
I never even implied it, however, that rather extreme miscommunication aside; I get it... I do.
The rate of inflation and material scarcity combined with broader consumer uncertainty are all valid factors difficult to forecast in this economy.
Particularly when there is no valid reason things need to be this bad if not for partisan fearmongering.
I just moved from Texas to Idaho, paid a company to do it.
My Mother in Law moved from the same city five months earlier.
Both about 2000 miles.
Her move cost $8000
Mine cost $19,600.
She came from a 3500 sqft house.
I came from a 1800 sqft Townhouse.
Shit is getting expensive as would be commonly seen in a nascent hyper-inflationary environment.
Should they have done a better job at their cost estimations last year?
I can't answer that, but people are still debating whether we are even in a recession, let alone the potential of an emergent hyper-inflation scenario...
It doesn't matter how inescapable our situation may be; we have made ignorance into a team sport.
Nonetheless $2800 is a kick in the pants.
But I'm going to pay it, gratefully.
Buy now or pay more later. Same deal with going from a 22 to a 23 MY truck (7.5K to 10K delta basically). There has already been more than a 5.5K increase in the 22 MY alone so far from when I got my truck last year.
I hate to break it to you but everyone has been paying 40% more for everything ( food, gas, house, you name it). Also aerospace is one of the worse industries to use as an example as they have been saved by the government many times. I own my own business, concrete has gone through the roof. When I went back to those paying for the project showing the cost of of raw goods they pay the difference.
If you don't want the fuel tank, great dont buy it. We still have that choice. However dont get upset when you want something else and a company says "go to hell, you burned me already".
I dont know anyones life or financial situation. However everything has gone up in the last 2 years. It sucks. I dont like it, but thats life. At the end of the day everything we do has consequences. A company took a risk for those on this forum. Now it is up to those that asked for it (in this case the fuel tank) to show it was a good risk.
Edit:
With a simple Google search air travel is up 33% and people are still paying.
Edit:
Can you provide an example from transfer flow that shows all of there tanks increasing 40% in the last month? They should be using the same raw materials as this one. Which if it's raw material cost increase these would also be affected. I would love to see the cost break down on this to justify this price but I know that won't happen.
I'm not trying to say things haven't increased in price as I'm fully aware of that. But this seems just flat out over priced.
I was simply trying to give another view point (which appears to be the minority) and I never did any poll or survey with transfer flow to give then the opportunity to tell me "to go to hell". More of my point was also that people on here seem to be shaming people for backing out or not holding their end of the agreement which in my opinion the business also isn't. At the point that they knew the price would be drastically different they should have redone the poll to see if the business case was still there. I could easy tell the business "go to hell, you already tried to burn me." Which I'm not. If they can get people to pay this price, good for them. If other members can pay $2800 for an extra 24 gals, good for them. For me, I took my truck, trailer and family across the country and had to stop more for bathroom breaks then gas. I'll take the $2800 and use it toward ~700 gals of gas.
When someone says to put them on the waiting list knowing that a company is going to design, test & submit for approval a item you want and you know the economy stinks as well as prices are going up for everything and then you start whining about the item you asked for is to expensive but you asked to be put on the waiting list committing to purchase it
Now dropping the “shaming” word that’s all the rage today thats a load of shit and part of the “woke” crap
If you put your name on the waiting list and now are backing out it means your word ain’t worth warm camel spit & neither are you
Lotta words flying around here, gonna say as someone just watching with interest because I'm still waiting for Ford to give me a VIN it seems you all are starting a needless argument.
It was a nice perspective to point out that the company was responsive to the interest in the product and we should keep that in mind when deciding about the investment. That said the proportions seem to have gotten blown up about screwing the company over with a "commitment" that I don't see substantiated unless I've missed something in reading this thread.
1: Someone mentioned 300tanks first run, where did that number come from? The photo of the message that was posted said they were gonna make 10 tanks then two batches of 36 before planning out any further production, that's 82 tanks. Even with the price increase there are folks interested and I don't suspect they'll get burned sitting on inventory produced for those 82tanks. Just my opinion.
2: Putting your name on a waiting list imho is not a commitment, its an indication of strong interest with a desire to be asked if you are committing ahead of the mass release. Any intelligent business isn't going to assume a waiting list is something like 90-100% commitment to purchase, they certainly assumed a lower percentage would purchase the final product, esp. with the increase in projected price, they aren't fools.
SO frankly yes its good to point out that supporting vendors that are responsive are good but giving guys shit that aren't a customer at the increased price point is just weird lashing out.
