Tranny issue
Texas243
Tremor Buff
Central texas
2012 F250 King Ranch
So tonight I was pulling my dump trailer with about 10k of gravel. While still in the driveway, I had to go up a hill. Running tow haul mode and started up the hill. Tranny downshifted from 5 to 4 then to 3. The hill keep coming and the rpm’s were steady at around 2300 but the truck was slowing down allot. We almost came to a stop. I manually downshifted to 2 then to 1, and the truck climbed the hill, but burning tranny smell filled the cab. 10k miles on her and this was the first pull.
Kinda pissed.
Wonder what damage was done and why it did not downshift when needed.
Any ideas????
Pics of your driveway, being in 5th gear and heading uphill?? Damn boss, that's a nice spot. :love:
To me is sounds like there was such a change in the terrain that the transmission just couldn't keep up with the overall weight. Then you shifted Manually. Hearing this sort of makes you wonder if it would be better to have the paddle shifters like the Raptor.
Unless you are having issues now with the transmission I can't believe there are issues.
I really thought to tranny would shift as it needed. I just got this feeling about pulling a 5th wheel in Colorado and smoking the tranny on a mountain where the trans just decided not to downshift.
It really wasn’t noticeable until we slowed down but the rpm’s stayed the same. Knew something was up.
Back in the day, when you felt that feeling, you pushed the clutch and dropped a gear- all good.
Well, I dropped my truck off at the dealer to see whats up with the tranny. They mentioned some of the 10 speeds had an issue with a snap ring not seated all the way allowing it to slip and/or not engage fully.
Shitty part is- They would not put me in line until my truck was there, but it is 3 to 4 weeks out before they can get it in. So I am out of a truck for up to 4 weeks before they even look at it.
They did however give me a loaner CAR, how nice. Drop off a haul truck, pick up a POS exploder.
I will keep this group informed as we move thru this.
To keep everyone in the loop- the dealership called yesterday and said my truck was "ready". I asked about what did they find. The found nothing. Test drive and everything worked as it should. I calmly explained that I never had an issue with driving and shifting, it was only in Tow Haul mode pulling a trailer up a steep hill. They could not replicate that scenario, so there's nothing wrong. I told him I would hook up my trailer and go to the same hill and burn the tranny down to prove there is an issue. I really don't want anyone in my tranny but I also don't wish to be stuck on a mountain pass with the tranny smoked.
Just another day. Sure did miss my truck when it was in the shop and happy to have it home.
We hear way too much these days about "smoking a Tranny". So many new definitions for normal words these days.:cry:
I wonder if traction control was kicking in and killing power
I'm assuming the dealer would have checked this, but is the transmission fluid low? Does the fluid look discolored / burnt smell?
The only other thing I could think of is some kind of solenoid / torque converter problem.
