Tranny blew and blew hard.....
If the truck is at a Ford dealer, I would demand they open up a case with Ford since you are just out of warranty and see if they will do anything for you. If it is a diesel you are under the 100,000 mile powertrain warranty and just over by time by 6 months for time. This is a known problem with these truck prior to 2023 and they should do something for you. I luckily had mine replaced in Nov. '24 and it has been fine since.
Ford may honor the warranty because it's so close to the window @Grabber is right. I was about to suggest the same thing! Good luck man that's no good... bills should only have more than 2 zeros on them when you're paying for something fun!
I sadly don't have a local transmission shop... Local is 4 hour way that would touch the 10r140
Check with a local repair shop. There is a local tire and repair shop near me. Years ago I stopped in and they ordered a suncoast trans for my old 5.9 Cummins truck. They swapped the trans out. Any repair shop should be able to do it. The sun coast trans is not crazy priced either.
Here’s what I would do if you plan on keeping it go with an aftermarket transmission like suncoast or alike any descent trans shop should be able to R&R that if you plan on fixing and dumping then find a shop to do a rebuild
13k with 3k refundable deposit for suncoast
Who is doing the work Ford dealership or a local shop??
While still relatively low miles, the rebuild will still have 69k on much of the remaining transmission.
I'd bet the "new" transmission from Ford parts is a rebuilt unit, not 100% to be factory fresh with 0 miles end-to-end.
These guys any good?
Firepunk is big on the Cummins platform. I haven’t followed what they do for Ford but I would look at them without a doubt.
I’ve used firepunk for several big power cummins builds I swear by them when it comes to dodge transmissions, I did not know they were messing with ford but it’s been a while since I’ve talked to them. Guess I should’ve clicked on the link first lol it’s not a firepunk built trans it’s a suncoast
I didn’t click the link either lol.
Awesome thanks for the recommendation
The dealer it doing it they gave me a loaner car and they opened a case for me.... If they didn't give me a loaner I be more upset but they have always taken care of me.
Ck $$$ Nex gen drivetrain
These guys are solid. I’ve had 2 whipple F150 10R80s built using them and no issues and will be doing my 10R140 trans once I get the whipple kit for it.
Budget for a better tune than what Whipple supplies! Are you installing yourself?
seems like their torque ratings off (which is really what kills most transmissions), Fairly certain the newer 6.7s (well those with the 10speed) are all dynoing right at 1000wtq at this point stock. That was from the 2020+
Doesnt the diesel have the 180?
