- Sep 24, 2021
- 327
- 434
- Retired Army/USCG
- YouBetcha
- 2022 F350 6.7PS Plat Tremor
Can you still use an AMP rear bumper step with this bumper and if so do ya'll think it was look good. I like the AMP step and use it all the time.
Thanks a great question I will ask!Can you still use an AMP rear bumper step with this bumper and if so do ya'll think it was look good. I like the AMP step and use it all the time.
Do you have pics of the front bumper?
24' three hoop, just for my visual pleasureThanks a great question I will ask!
For what year? Also, this is available in a single hoop or three hoop.
No, sorry, my bad. The 3" receiver on the Trophy Hitch.3" Lift? Yes of course.
Looking great!!
Happy to chime in here as we are the online store for these...Any reason why you went TR rather than Buckstop? I know they’re identical, but im trying to decide which branding I want on my front and rear bumpers.
- An easy to notice main difference between the trail ready and buckstop lines will be the shackle style recovery points vs OEM points.
- The TR front bumpers will always have welded hoops, whereas buckstop's are bolted on.
- TR is only avaible in steel whereas we can order buckstop in all steel or in a hybrid configuration.
- TR has slight designs tweaks, mostly aesthetic.
- For the Pre-2023 Super Duty trucks the difference were more apparent I feel.
If a customer is worried about weight, then I recommend buckstop so we can opt for the hybrid option which saves around 90 lbs. If they want the beefiest option, Trail Ready is usually where they end up. You cant go wrong either way.
We can custom build your setup with specific lighting cutouts, special tricks with the winch door, additional headlight protection, powdercoat options, etc etc.
Reach out
Buckstop and Trailready bumpers dont truck up as much as other brands. Part of that is that they are designed to house the Warn 16.5TI-S, which I believe is the ideal which for these bigs trucks.Thanks man! What do you recc for my truck then—
I’m pretty set on the buckstop rear with square cut outs and black top powdercoat plate.
As far as front goes, hard to say— Looking for as tight fitting as possible, but want all ACC/parking functionality with full guard.
