Hello have you since had this issue fixed and what was the issue if you had it fixed? I have a 22’ that does the same thing. Mine flashes the “brake gain” screen as if I’m increasing or decreasing brake gain and immediately after the trailer disconnected warning populates. I had the dealer check they said it was all good and that it’s my travel trailer. I had my travel trailer rewired. New 7 way pin new brake harness and lights, new magnets. Picked up the trailer from the shop and a few miles down the road, BING! Trailer disconnected warning. I’ve taken the plug off from my truck cleaned it and packed it with dielectric grease and still warning comes up.2021 Tremor Lariat 7.3 purchased last month. Love the truck and happy with almost everything until this happens. Randomly without any trailer attached I get a warning and chime "Trailer Connected" then followed by "Trailer Disconnected". Usually repeats quite a few times along with warning that the Blind Spot warning system disabled. Very frustrating and annoying with all the chimes. Then it won't happen again for a day or two and then re-appears. So I searched the web and found a few videos and posts, but none exactly matching this issue. One suggested that earlier Super Duty's (I think 2018) had similar issue and solution was replacement of the 7/4 Pin connector in the bumper. Did that - nope - problem still exists. Checked most all connections under the bumper and dropped the spare to access all of the trailer plug connectors. (Pulled each apart and reconnected each one - all looked OK). Appointment with the dealer in a couple weeks - not anxious for that since it's an intermittent problem. Been there before - usually "no codes - all looks fine". Will bring video I have of this while driving to show -- hopefully they can track this down...
Anyone experience this or have similar issue?
