- Apr 1, 2020
- 541
- 1,470
- Air Force Reserve, Spouse
- Fire Captain
- 2020 F-250 XLT Tremor 6.7
To add to this the LT to P tire sweater is most common on half ton trucks. Many of them now come with a P tire for ride quality.It’s just saying that if you switch from our tire: LT285/75r18 to say a P315/70r18 (not sure if that’s a real size but go with me) that you need to reduce the load capacity of the P metric tire by 10% (at whatever pressure you select). Their footnote says that recommendation is mandated by FMVSS.
Edit: I’d like to remove flotation tires from my original statement. Page 5 mentions them but Toyo doesn’t appear to sell any flotation tires that aren’t listed as light truck tires so their doesn’t seem to be a point to that portion of the statement (backed up by their calculation on page 10). It’s still valid for P metric and metric tires though.
They do make flotation tires that are non LT. Mostly common in older cars. Only select manufacturers and it's not an issue in the 3/4+ ton vehicles.
Almost all retail tire dealers will only be comfortable installing a replacement tire that meets or exceeds the weight capacity of the original tire and load rating (D, E etc).
With that the oem tires on the tremor are way over kill for weight. At 80 psi (the recommended inflation) they carry a combined 8000lbs~ and if memory serves me the rear axle is rated for 6000lbs? The stock tire can be as low as 65psi and still carry the max axle weight.
So from a non Rubber Manufacturers Association (they are the ones who make the weight rating recommendations, not Toyo, it's just an industry standard) standpoint there are a lot of tires that can carry the max load of the Tremor.
So you should be good for 38s
