Tires for Tremor & Camper
I’m still in America and wondering the same thing. I had 37’s on beadlocks with my built JL Rubicon but don’t know why I’d want to go with 37’s on my F350 Tremor. Seriously I haven’t thought of a reason other than to spend more of my money for new wheels, tires and lift. 37’s did radically change the geometry of my stock JL. I’m OK with the stock Tremor.
That is my Tremor on 37’s up near the top, no lift or aftermarket wheels and I sold my take offs for $700…. So cost was pretty minimal all things considered. I did it 50% for looks and the other 50% to drive my buddy with a brand new lifted Cummins crazy since he just did 35’s and now he’s super upset mine are bigger. Yeah AMERICA!!! 🇺🇸
In all honesty I think they look much more proportional to the dimensions of the truck.
I know the mileage discussion has probably been beat to death but I just got a regular old 22' platinum (no tremor) with the stockies and I am really enjoying the efficiency (21+ mpg on highway) and am looking to add a camper. I expect the camper will mess up the mileage noticeably but I want to preserve it as much as possible. I love the look of all terrains on a small wheel but I know that the more aggressive tires really can effect mileage and they also negatively affect just about every other metric on asphalt (of particular concern is wet weather braking). I was curious if any of y'all know just how bad switching from the 275/65/20 setup to a smaller wheel like an 18" with the 35s would be for mileage and performance. Thanks everybody!
I am also interested to know if I have that thicker sidewall on a H/T tire could also give me a cool look while still preserving mileage.
Apologies if you already mentioned it, but is that a 7.3 or 6.7 you have?
I have the 6.7. If I was getting 20mpg on the gasser, that would be amazing!! I am leaning towards just sticking with 275/65/20 setup because, it looks like if I go to pretty much any 18" wheel 35" tire setup, I am probably going to lose at least 1 mpg if not more which while I definitely think it looks alot better, I think can have a cool looking 275/65/20 setup and preserve all the mpg I can. It doesn't look that much different. The one thing I dont love about a 20inch rim is that it is possible to get curb rash on a really high curb which sucks.
Its unfortunate that its hard to get real facts about this stuff because there probably is a 35" tire on an 18" wheel that looks great and has solid performance and mileage and there are probably very inefficient and poorly performing 275/65/20 tires and so there is a chance that you are getting less aesthetically and gaining nothing because the tire just doesn't have good rolling resistance and stats. It would be cool if they had like a rating for tires by efficiency or we had some sort of data driven spreadsheet that could help us out.
I know that no matter what anyone says, we all would love to maximize looks and efficiency. I totally respect whichever compromise one wants to make but I think we can do better! Bake our cake and eat it too.
Yeah, 20mpg is about impossible on a 7.3. Partially asked to see if ya said 7.3 then we would all know your full of sh*t 😁 . I went from a oem Michelin 275/65r20 to a 285/65r20 Cooper at3 xlt on a 17' 6.2 f250. Ended up being 1/3" taller looked better and .5mpg impact tops. Was still smooth and quiet. I went from a 33" to a 37" on my 7.3 and took about 2mpg hit on highway mpg but that's 4" and 20-25lb/tire increase.
Stock Duratrac tires are EOL and I'm ready for new ones. I want to keep my stock 18" wheels. I'm trying to optimize for too many different needs/desires, and need someone to talk sense into me.
2021 F350 Lariat Tremor SRW, 6.75' bed, Carli Pin Top & rear air bags, OEV Flat Bed and a Cirrus 820 Camper.
Weighed in at 12,200lbs fully loaded (4700lbs front axle, 7500lbs rear axle).
We're full timing and on our way to Baja and foresee lots of dirt & gravel roads, lots of sand, but also lots of long paved highways. I hate how small the stock Duratracs look on my rig, so I would like something bigger, but I'm also scared of losing even more gas mileage and losing on-road abilities. Oh and they need to have the highest possible load rating (as close to 4000 as possible). So I want it all. Looks, off road/sand, on road, gas mileage. Not asking for much! :ROFLMAO:
Options I'm considering:
- 37s ... maybe something less aggressive, an A/T or hybrid tire like the Nitto Recon Grappler or the Toyo Open Country A/T?
- 35s ... stick to the same size, Duratracs (hate them), or the Recon Grappler in 35, or similar?
- Yoko Geo M/T in 315/70R18 - this is a 35.6" tire, quite a bit beefier than the stock Duratracs. Weighs basically the same as 37s, at which point may as well go with 37s, no?
Thoughts? Ideas? Opinions? Talk sense into me!
The Rig...
One thing you might want to consider if you haven't already is the availability of replacement tires in baja. I know more and more people are spending time with big rigs in baja these days but if you blow out a sidewall on a 37 inch tire, how much is it going to cost you to get that same tire if you're in somewhere remote in baja. If you didn't have the camper, you might be able to take advantage of 37's more often but I'd focus more on looks and the practicality of what a 35 inch tire can offer. Sweet setup and good problems to have!
Hey that's a really valuable insight & nudge, thank you!
I hadn't considered tire availability at all. I do in fact plan to do a full Pan-American Highway trip down to the furthest southern Patagonian tip in my rig (hence the gas vs diesel decision) and that should be a factor I consider. I assume 37s are much harder to come by down south than 35s...
My hope is one, to fit a full size spare into my stock location, two, that the 37s would be beefier tires in general and less likely to blow a sidewall than the 35s.
Its on my list too…
Driving to Ushuaia is a lofty goal but certainly doable. I have some friends doing it right now in a Galdiator but they are taking years to do it and drive around the world.
I hope you make that a reality, it’s a brutal drive through some parts and a big vehicle can take some extra planning but certainly doable. There’s quite a few threads on Expo that document people do it.
We have run Toyo At3's with great success over the years, and have found the lifespan to be much greater than the BFG Ko2's with heavier vehicles, though I do think the Ko2s are an amazing tire on lighter vehicles like jeeps and toyotas.
Currently we are running Toyo's new RT Trail. More aggressive which will mean slightly more road noise than the At3, and slightly less wet weather handling, but lightyears ahead of an MT.
The Rig...
I had the same problem and ended up with 37x12.5 KM3s. They work on the 8" stock wheels and have a relatively close load rating (128Q, 75psi) but I have to deal with a bit extra noise and slightly lower fuel mileage. Things that I can live with. Everything seems to be a compromise with a camper....
Sorry for the bad pics. I couldn't find one with the tires and camper at the same time.
View attachment 134003View attachment 134004
I have the same setup with Northern Lite 8-11. What if any suspension modifications have you made?
The Rig...
I just put on my 21 6.7 Tremor the
Cooper Discoverer at3 xlt stock size
I love these tires…super quiet, smooth, comfortable ride…..60k mile tire
Rides like a Cadillac now…I’m not an off-roader so they suit me perfectly!!
Some may ask, “Why’d you get a Tremor if you don’t off-road?” That’s a valid question….Answer is: I needed a diesel to pull my big 5th wheel and I wanted only the Ford Powerstroke….nothing was available in the summer of 2021 except my Lariat Tremor (had to drive 6 hours each way to get it)
And they look so damn cool the Tremors…..I love it!!!
I used the Cooper Discoverer AT3 XLT on my current fullsize pickup. Have loved these tires and I run a slide-in pickup camper and do a lot of high speed washboard road, mountain trail driving and trips to UT on trails that are more "challenging" than I have a right to be on with this rig (and have my wife's claw marks in the dash to prove it. Ha). I air them down for trail work and back up with ARB air compressor.
My Superduty (non-Tremor because we wanted Supercab rather than Supercrew) just changed to "Built" status. While there are some other tires out there I'm tempted to try, I just can't move away from these Coopers. Getting a set of 285/75R18 to put on a set of 18" Tremor take off wheels I bought last month. The Cooper AT3 XLT tires have been the perfect tire for us. Most of our Montana trails are dry and rocky. Same for the trails we frequent in UT. But I've ended up in long mud days in both States and they real well. A mud terrain tread would clean out better, but I get caught in mud once or twice a year and mud performance is the lowest priority on my list. Tires are super quiet on the road, grip great for the trail terrain we frequent, look great, have been tough (no chunking, strong sidewalls and tread, etc.)
They are not snowpeak rated, but I have the camper off in the winter and then run dedicated winter tires (not studded) December through March as we frequent trailheads to snowmobile/snowbike, snowshoe/XC ski, etc. and no all-terrain tire beats a dedicated winter tire for winter roads and trails. I swap back to summer tires as soon as the daytime temps are consistently above about 40F or so. On my fullsize pickups, I've always run Blizzak DM-V2. Will try Blizzak LT for the SuperDuty and put them on my pickups stock 20" wheels.
I do my own seasonal tire swaps and tire rotations so always have two sets of wheels/tires: An all-terrain set for camper season and set of dedicated winter tires for when the camper is off and snow is flying.
