If you plan on driving on the repaired tire until the tread is worn out (normal replacement time for the tire), then yes - patch and plug. The plug is a quick, reasonably safe and (much easier) roadside repair to get you going again until you can have the tire properly patched, although many people just keep driving on the plugged tire for thousands of miles anyhow. Not many people can break the bead, dismount the tire, patch it and re-bead it on the side of the road
. Plug kit is for emergency use (but as said, sometimes it also becomes the permanent repair until eventual replacement of the tire).
