Mine is leveled with 37s. Same wheels, same stick out. No rubbing no trimming.
Lip Bolt Kit | MRW | Black
Change the look of your Method Race Wheels up with this set of black lip bolts. Each kit contains enough lip bolts for 1 (one) wheel. *NOT FOR BEADLOCK RINGS*www.methodracewheels.com
That was one of the reasons why I went with the 701 HD, plus it was a style that I liked more than any other, and one I hadn’t seen on any other Super Duty.....yet. LolWheels and tires are here....truck is supposed to arrive 6 Dec. I am disappointed that Method does not include black lip bolts with expensive black wheels...I had to 5 of these kits...ridiculous.
Negative on the the Gold Dots!!Not into a pop of color?
Damn that adds up!
Concur with Mountain man....I have a +18 offset and they are perfect...just peak out from stock fenders!Hi all,
I am new to super duty and waiting for local dealer to put in an order for a 2021 f350, SRW, 7.3, star white, Tremor. Based on great info from the site I am looking at the following tires and wheels. My question is do you think these will fit the stock set up without any modifications like level kit, blocks, etc.? I am going for the wider tire look without too much sticking out from the fenders. Any advice is much appreciated, thanks.
Tires: nitto-ridge-grappler 35x12.5x18
https://www.discounttire.com/buy-tires/nitto-ridge-grappler
Wheels: method 305 NV HD 18x9, 8-170, +18 offset (HD version 4500lb load capacity)
https://www.discounttire.com/buy-wheels/method-race-wheels-mr305-nv-hd
Stock (285x75x18…..18x9, +40offset) vs upgrade tire wheel offset comparison tool:
https://tiresize.com/wheel-offset-calculator/
The Arsenal would look good. Is your truck silver?Ok what wheels do y’all think would look best?
YeahThe Arsenal would look good. Is your truck silver?
What size receiver came on your truck? Just ordered my tremor, 8 week build time.I have the exact combination you are looking at w/ +18 offset in stock suspension configuration. Love them! They fit perfect, look & perform great, no trimming, no rubbing.
Which level did you end up going with on this?Mine is leveled with 37s. Same wheels, same stick out. No rubbing no trimming.
In my Sig...Which level did you end up going with on this?
What did you use to level your rake..??Mine is leveled with 37s. Same wheels, same stick out. No rubbing no trimming.
My stock tires are done at 36K miles and I want to go with this set up. Did you keep the stock spare or upgrade that as well?I have the exact combination you are looking at w/ +18 offset in stock suspension configuration. Love them! They fit perfect, look & perform great, no trimming, no rubbing.
I left my stock spare alone. Just make sure it goes on the front axle if you ever need to use it. That way you won’t have two different diameter wheels on the rear spinning the differential at different speeds.My stock tires are done at 36K miles and I want to go with this set up. Did you keep the stock spare or upgrade that as well?
