Ticking Noise… Unfamiliar
Anyone recognize or have this ticking sound?
Yep, my 26 HO with 2200 miles has it after it warms up. The service department checked it out and said it is normal. It can be annoying if you are standing next to the truck.
My son who works on the 6.7 (and many others) sent me an Autel MX808 tablet so I can generate a regen when needed while standing still. He warned me to do it in an open area; exhaust pointed to no flammable material because it gets very hot and engine is running at about 2000 rpm. He also said it's not for the faint of heart. :ROFLMAO:
Good news is, I haven't had to use it. A long trip occasionally takes care of everything. But I can use it to check other stuff as well.
when i do a static regen on mine, it run's at 1600 rpm for 20 to 25 minutes. i just sit there and letter rip !! make sure you have plenty of fuel in the tank if you do a static regen.
I've always done 100% of my own oil changes on my 22. I've always used Rotella T6 since new. I've never noticed any ticking sound, before or after an oil change, and I consider myself super focused about noticing or detecting any changes in how my vehicles run and feel. I've also got an 02 7.3 on the identical maintenance regime., and also never detected anything.
So I'm curious if there could be any relationship on this ticking noise issue with the oil brand and weight people use?
I read this post a few days ago after I noticed a similar ticking about a week ago. It started very light but today I noticed it seemed much louder. There is about 3.5K on the oil. Same kind of oil as last change with no noise, amsoil 5w40 full syn max duty. Im certain it's not regen. So here's a good look at my tire.
  • IMG_6403.mp4
    5.7 MB
I hear exactly what you are talking about. While I have yet to hear this in the current truck, I have heard it off and on in the ‘15. You are using the same exact oil I did. It sounds like a rocker to me, but I have never found an explanation.
That's kinda what I was afraid of. I can't imagine what kinda mess that would be considering the hydraulic valve train.
It’s actually not bad. Replacements are about $100/ each. You’d want to do all 4 if you opened the valve cover. As usual with these engines, there is a lot of junk to take off to actually get to the valve cover.
That said, it does not sound like injector or bottom end knock. It really isn’t loud enough to me to be rockers.
I put 70k on my old truck after I first noticed it. The new owner has another 30 so far. Hasn’t skipped a beat.
If it's a pretty straight forward fix I'll be good with that. 3.5k ago the oil analysis was very clean. I'm gathering a stack of suspension parts, so the last thing I want no is a broken engine.
Honestly, though, I don’t think it’s rockers. I think it’s just the song of the PSD engine. If it gets louder / worse, then maybe start digging in. First thing would be just an oil sample.
Yes, thats what I planned to do, just keep an ear on it for a bit. I have noticed it it for about a week. today just seemed louder. Do you think a small rocker issue may show up on an oil analysys?
edit: what I mean by small as it's not like really loud like clanking. of course it could possibly turn out to be significant, worst case scenario.
I believe so. Circled below is where the wear usually starts. The longer arms typically go first. Now, I’m talking hundreds of thousands of miles. Rare for it to be a typical failure in a young engine. When they begin to fail, they start rubbing the stationary “bracket” they are attached to. When it gets really bad they’ll move enough to shift and not even open their respective valve. That’s when the noise is really bad.
Anyway, point being, yes the metal will show in analysis. The downside is analysis will only tell you what kind of metal is wearing. Not what it is coming from.
Note: I’m not fully up to speed on the newest engine design, so the photo might not be the exact same as what is in your engine. To my knowledge there have been no significant redesign of that part train since 2012ish.
That great info for a gearhead, without having to do all the reading and experimentation myself. I get it, thanks. Maybe I need to do some full throttle pulls and see if it gets better or worse, maybe.
The Typewriter Sound: Originates near the bell housing (2011–2026 models). It sounds like an old typewriter, but it is just normal movement and oil clearance at the rear crankshaft thrust washer. Ford issued a Technical Service Bulletin stating this design characteristic is completely normal and requires no repair.
