Suspension component help: build
Mguilbault
Tremor Fan
Phoenix AZ
2024 F250
I am finally pulling the trigger with PMF having their one sale a year. Question is do I need to upgrade the tie rod and drag link or one or the other?
Currently I have the springs and shocks and looking at the following:
Radius arm drop bracket with crossmember support
Adjustable track bar
Extended s/s brake lines
Bump stops
Sway bar end links
**tie rod bar with upgraded tie rod ends ??
**drag link ??
1" lift?? 6" lift??
Tie rod/drag links really don't change that much do they?? Most people get the adjustable trac bar at a minimum.
Bump stops
Sway bar end links
Yes, to the above. I'd suggest those things if you are buying from one source. Not sure why your question seemed to focus on the tie rod/tie rod ends/drag link. Maybe a drop pitman arm if you really needed something else.
I think the terms tie rod and drag link are close to the same. Not sure myself. Seems to be two terms referencing the same thing.
Tie rod connects the two front wheels so they both turn at the same time.
Drag link connects the steering via the pitman arm to the passenger side steering knuckle.
Track bar attaches the axle to the frame to keep it centered side to side.
-I'd do the 3 link radius arms instead
-Yes, you'll want this to center yout axle
-Yes, from PMF or elswhere
Bump stops
-Yes, helps keep your tires from contacting fenders. Extension brackets work well too
Sway bar end links
Yes, keeps sway bar geometry correct
Maybe- Not really needed, but nice to have.
Also consider their dual steering stabilizer setup
I'd recommend calling PMF to get their recommendations.
I put a 4.5" Alpha lift on my 2013 F350. The adjustable 3 link radius arms make dialing in the caster super easy. The PMF steering components are WAY beefier than stock.
Where is this BF PMF Sale you speak of?!?! Do you have to be an in-person AZ local to take advantage of it? Haha
I built up my front leveling kit with the PMF/Icon progressive coils and just Bilstein shocks all around for now the last couple weeks.
But I (FINALLY) received my full progressive leaf springs from them too. Funniest thing was… Those Mother Truckers are sooo fricken heavy (~300lbs) that they actually smoothed out my rear suspension on my drive home without even being installed!! 😂
But seriously… I’ll let you know how they “feel” once I get them installed this weekend!
I would see what Trevor recommends, first of all.
I'd do:
Coils
Shocks
Track bar
Bump stops
Sway bar drop/splined sway bar
Radius Arm drops
3 link arms
Rear deavers
Air bag setup(the PMF long travel to stick to one brand)
I'd skip the Tie Rod and Drag link unless Trevor says to do the Drag link
Of course you may want to do that all in stages as it gets pricey
How do you like the leafs?
I am debating on ordering a set. Also, how much was shipping?
