Strange TPMS Issue?
CRS250
Alabama
Army
2022 F250 Tremor 7.3
2015 Mustang GT
Picked up my '22 Tremor last Saturday. Unfortunately, I made the rookie error of not looking at the TPMS screen before I drove off the lot (no TPMS light at the time). Monday morning, driving to work, I hear the friendly "ding, ding" and look down to see the Low Tire Pressure screen appear. Showed both rear tires low (49 & 50 PSI showing). Get to work and PSI seems steady so no, apparent leak. After work, I air both rear tires up to 60 PSI, drive 5 miles and light still on. Drive to work the next morning, light still on. Go to the DMV at lunch to get the tag, light still on. Get in the truck to drive home, after work, and light is OFF and has not come back on since. So it took nearly 48 hours for the system to register the rear tires as low and 24 hours and at least 50 miles, at highway speeds, for the light to go off after air-up. Since the light is now off, I have no need to spend time back at the dealership and the salesman has no answer, of course. Just curious if anyone here, who knows the Ford systems better than I do, has a plausible explanation?
I had that issue with my 2022. dealer had to reset them after getting them to the correct pressures. pressures from the factory are 60 front and 70 rears
60 is too low for the rears without changing the values. I had the dealer drop mine to 40 front/rear. I run 45 in the front and 40 in the rear.
I hear you but the rears were at 49/50 when I picked the truck up and the light was OFF. 48 hours later, the light comes ON, out of blue. I air-up the rears to 60 now and the light is OFF but it took 24 hours and I had driven 50+ miles before the light went back OFF. My door says 60 front and 70 rear. The light should not come on at 10 PSI below max. I had a '17 SD and I used to keep the rears at 55, even though the door sticker said 70, and the light never came on. Besides, my fronts are at 50 and the system only said the rears were low. I am still running 50 front. Seems I read somewhere that the threshold is 15 PSI below factory setting.
I can 100% say the light comes on 10psi under defined pressures. Remember, the TPMS reads in 10ths but displays whole numbers meaning the truck says 50 but it could be 50.9. Also, the truck's on board is a guideline and isnt suppose to be used as a gauge. Says it in the manual as well.
Still doesn't explain why the light went OFF after 24 hours and 50+ miles (either hot or cold tires, the light is staying OFF now. I do realize the tire pressure changes with temperature). When I just parked it, after lunch, both rears were reading 59, which, by your reasoning, should mean the TPMS light would be ON. Regardless, I don't wish to debate the PSI range of the system. I was just curious if anyone could explain why it took 48 hours for the system to register BOTH rear tires were low and 24 hours for the system to correct once the rears were aired-up.
