Stock Tremor running board swap to factory power boards
I was under the impression the Platinums were already wired up and programmed for the Power Running boards . Has anyone checked that ? I have a set of original power steps off my 22 platinum tremor for sale . I have pics of the wiring plug and play that should be there for the OEM steps
Hopefully that is not the case as I have a platinum or rather picking up my platinum this weekend so hopefully it is plug and play and maybe a fuse/relay and then maybe at worst some forscan programming. Looking for some info as I am sure someone has done this
Did you ever find out if your plat tremor already had the pre wiring plug and play harnesses pre installed? I have pics of mine where they are . 2022 plat tewmkr
I recently replaced my fixed Tremor running boards on my 22 platinum with AMP XLs. These have the additional 3" drop. Before doing this I checked with two Ford dealers asking whether my truck would have come with the factory wiring harness. Both said no. Consequently I had a private shop install the XPs and they're great. No onscreen indications but that's ok, they deploy when the door opens. They'll stay down if you hold your foot on them while closing the door. Only thing you can't do is leave them down while driving but why would you. But the AMP XP is substantially more beefy than the stock boards Ford puts on. They have a very nice under carriage rocker panel type housing.
I swapped out to the Amp XL boards to get a 3" lower step and love them. Like mentioned above they deploy/close when opening/closing the door.
I also installed the override switch and can deploy/close them without opening the door. Can leave them down for a door bumper for people that park too close too.
You can get the switch from AMP or even from Amazon.
^^^ I ordered my 23 with power boards..will i be able to leave them down for door ding protection?..Or will I need that gizmo??
You can set them to be in the down position, for the factory steps. The only time I really use this feature is when washing the truck. The rest of the time it is set to auto.
Sorry to chime in on the late post. If you can get a set of used steps as take offs, it's more worth it.
https://www.ford-trucks.com/forums/...unning-boards-to-my-truck.html?ispreloading=1
I'm in the starting process of figuring this out. It can be programmed via forscan. I just need to find the steps and codes out. My 23 kr tremor came in and dealer didn't reselect the power boards. Ugh. I have a pair of 23 take offs coming in the mail currently.
Anyone have any luck adding ford oem power boards yet?
I don’t see why it would be worth the trouble when adding amp steps is easy as can be and they are way better than the factory steps.
Did you end up getting them to work? I just ordered a set of take-offs, and if I can't get them to tie into the truck to act as OEM, then I'm just going to program a Raspberry Pi I have running in the truck to control them.
