Standalone open carry belt for women
Blade420Play🔪🏆
hombre araña
Mount Pleasant, South Carolina
24 Lariat Tremor 7.3 Godzilla Antimatter Blue 🔵
85 Bronco
So I have bought her two separate paddle style owb holsters but they pull on her pants and she doesn't like it. She showed me a leather western style belt but those are generally for revolvers. I'm looking for a belt that she can wear outside of her pants that would be similar to a western style carry but accommodate a M&P shield ez 380. Any suggestions from you guys' wives girlfriends or whatnot 🤷
Edit: she does wear a jacket 95% of the time so it generally wouldn't be "open carry" just not IWB
This is what she showed me. But she doesn't need two and it obviously has to work with her pistol
I'm also not a fan of open carry for most situations, but I have seen women wear a belt kinda like the western rig you posted, but with a regular holster.
Curious if this is for every day carry, or something else?
Not a fan of open carry for anyone, let alone women. They can be surprise overpowered too easily so the element of surprise is the best tactic.
Also would recommend a fixed blade in the form of a push dagger or Benchmade SOCP (or similar). If there are no knife restrictions in your state sharpen both sides of the dagger. Something that their entire hand can encompass and not as easily taken.
A solid battle belt (I like Ferro Concepts but there are a ton of good options) with a Safariland level III retention holster would be my pick if concealed carry is not an option. Make sure she practices her draw regularly if you go that route. Most good battle belts will have an inner belt that goes through your belt-loops and secures to the rigid outer belt via velcro. The weight of the gun all but disappears. Not sure if they have good retention options for that specific gun, but would be a good excuse to upgrade the gun as well. If she has the EZ because it's difficult to manipulate the slide, I can show you some techniques that will make it easy to rack just about any slide.
If it's just for carrying in the woods or something, she won't need that level of retention. I would avoid leather if you can due to the higher risk of NDs from the leather folding into the trigger guard on re-holster.
I think she's just looking at the leather because it's wide and thick. She likes the paddle style kydex holster with the trigger guard retention/button release. She had the Walther .22 but that thing is straight garbage. She tried the G19 first but didn't like how big it is and how much recoil it gave her. We ended up at the range/store we go to and the lady there handed her the EZ and she likes it 🤷. She has had arthritis for all her life so if she finds anything tolerable, she'll stick with it. I'll look at that first belt you mentioned and see where that gets me 😉
Every day. She doesn't go too many places. Mostly scared at home now because of that damn kid with the rocks.
I CC a Glock 43X with small mag extension. I have a bunch of pistols and it’s my favorite to carry by far.
OHHHHHHH I remember the rocks post! I now have more clarity with her situation mostly being at the house. Open carry in the house certainly an option.
Gotcha. Read your first post too fast and thought you were looking for holsters, too. That's what my leather comment was aimed at. There are some great leather gun belts out there if she likes leather. Rigid is the key - helps with even weight distribution so it doesn't feel like it's pulling your pants down. That's where battle belts like the Ferro really shine. I have a steel-core leather gun belt that I'll wear with slacks and it works almost as well.
Another option to consider is a belly band (with kydex for trigger protection of course). Crossbreed makes a decent one. They can be worn like a belt and are very comfortable. My wife wears hers up high like you would normally wear a belly band and loves it. She wears it every single day. I wear mine like a belt when I'm running or really any time I'm in athletic clothes.
Hopefully some of that helps.
My daughter uses a belly band with certain clothing. Works well for her. Hers has a built in holster of sorts that covers the trigger guard.
Lots of good companies out there, i have a lot of great belts, the 5.11 web belts, and anything else with a lot of structure are t gonna be pretty but function is always better than form.
I picked up a Nextbelt Supreme from Bass Pro last month. I'm a big fan. Very sturdy and has 1/4" adjustments for pre and post poops.
