Hey guys, long time lurker first time posting. Bought a 2022 F250 XLT BAP in December and in the process of leveling the suspension with the Carli commuter setup. Springs/shocks/brake lines/track bar installed after a hell of a time getting the truck high enough for the springs to go in.
Went with SPC caster shims, 2.3 on driver and 2.6 on passenger side. Driver side went on fine. Having a major issue getting the passenger side shim installed - it will go just deep enough into the knuckle for the castle nut top to be flush with the ball joint stud, not even close to getting the cotter pin in - Hammered it down, beat every angle with dead blow/peen, cranked on castle nut, etc. The nut is extremely tight and I’m afraid if I crank more I’d strip the BJ stud.
Firestone won’t touch it, local reputable shop said take it to alignment shop so I did, now they just called and said they won’t touch it. I would post pics but haven’t picked the truck up yet. At a loss as to why it won’t go down on the BJ stud/into the knuckle far enough.
Stressing me out after three different shops said take it elsewhere over a simple caster shim issue. My last resort is the dealer and I know they’ll go in dry with the aftermarket goods on there. If anyone has suggestions/ideas I’m all ears. Thank you in advance.
Flew to Pittsburgh to pick her up with 7k miles -
