Spark Plug Stuck in Head
jasoncw
Founding Member 📜
Brownstown, MI
2022 F350 Lariat Tremor
2017 SHO
Non-Tremor related, but I figure there are plenty of wrench turners here, so maybe I can get some suggestions.
My son has a 2013 Fusion with the 1.6L. Currently around 110k miles on it. The car has been extremely reliable until it hit 6 digits. Now it seems to be a money pit. Current issue, I have been getting sporadic misfires on cylinder 1, to the point where it wouldn't stay running this morning. It would fire up, run about 15 seconds, then die. So not quite like a simple misfire, but I was hopeful.
Picked up plugs, and the swap on this car is extremely simple. Everything exposed on top, easy access. Replaced #4, 3, 2, then got to #1. It is stuck in the head. I haven't had to deal with this in the past, so I'm wondering if there is a trick to getting it out without destroying the head. It was extremely tight to start, but I was able to move it, maybe 1/16 of a turn. I can turn it back and forth, but it won't loosen any more. I didn't use too much force, because I assume what will happen.
So now, what next? Seems almost like I need to muscle it out, which will likely destroy the threads, which could hopefully be solved with a helicoil. Any other thoughts?
Get some AeroKroil first and soak the area down. If you were able to move it slightly, the Kroil should wick down there and help. Try to move it back and forth slightly (no muscling) while the Kroil seeps down the threads.
Yep, agree with the soak technique. Helicoil should be possible if you have to go down that path. The fact that it is moving at all is a good sign. Often the threads get a bit mucked up and can be chased with a tap coated with grease w/o the need for a helicoil though.
Thanks for the tip. Is AeroKroil a different type of penetrant than say PB Blaster? Or just a better penetrant?
Just used an awful lot in the aviation industry. PB blaster penetrant should work too.
