- OP 🔹
- #21
Appreciate the replies so far!
What does this mean? My door is squeaky, will washing the seals help?Have you washed your door seals too? That made a big difference for me.
If your seals are squeaky, go get some waterproof plumber grease and put on the seals. It worked on my '15 with squeaky front door seals. Use sparingly and rub it into the seal, you might want to use rubber gloves. Since it is waterproof it will last awhile. I used Danco which you can get at Home Depot.What does this mean? My door is squeaky, will washing the seals help?
Any information or builds on the F150 Forum that used LizardSkin Coatings [Order of application(s) ----> SC - Sound Control; CI - Ceramic Insulation; TopCoat (Urethane)]? I talked to Cory at LizardSkin and he said their products can be applied interior or exterior on the floor. If applied to the exterior floor, must spray a coat of primer before applying LizardSkin SC. Cory said the advantage of LizardSkin is no seams. However, he does know some customers have used LizardSkin products in combination with Dynamat products.Haven't done anything on the 2020 yet but my 2012 f150 I found that some dynamat (or similar) with MLV on top with no seams (glued an extra strip over seams) on floor worked best and if you don't have sunroof best thing is dynamat, radiant barrier, 3M SM600L Thinsulate. I found doing the roof and back wall helped the most. Don't have pictures but built some baffles around those air vents to block sound but still allow fresh air in.
There was a bunch of good info and builds on the F150 Forum.
