SERPENTINE BELT QUESTION 6.7
Figured I'd add some of my experiences with belts. But for those that don't wanna read it all, I'll put some important notes up top here.
Gates is the typical belt replacement I use and they recommend 60K inspection and 90k replacement intervals. Also keep an eye out for the HD versions of your belt, supposedly more durable.
Don't forget your tensioner while replacing belts! They do wear out and can cause misalignment in the drive pulley system leading to premature belt wear or failure. Or worse they can explode, yes I have seen one.
Fans do not need to be removed. With some time and patience you can feed the belt from behind the fan at the top, spin and feed, spin and feed and pull the belt through to the proper side, done this dozens of times.
If adding HP upgrades such as a dual fueler setup, pay close attention to making sure all pulleys are in the same plane and parallel. This may seem obvious but it is surprising how the smallest misalignment can cause excessive belt wear.
When modifications that change pulley size such as high amp alternator(smaller pulley usually) or upgraded damper/harmonic balancer(larger pulley usually) take special care to note tensioner placement on stock setup vs your new upgrade. Often times this change puts the tensioner out of its effective range. You might get something like a chirp when the AC kicks on. To remedy this you may need a newly sized belt or start messing with idler pulley sizes to compensate.
7.3Ls pain in the ass to do if you have the "wrong" upper coolant hose running through the belt, there's no way to replace without disconnecting this hose. However if you do one, get the updated upper coolant hose(wish I remembered more details or specifics, might be the psd expedition or certain year super duty upper hose) that routes around the belt. The front cover in 7.3Ls actually have spot the hose should line up and be able to be retained to. Regardless get this hose.
6.0Ls been ages since I've had one of these in the garage and do remember it being OK, didn't have to drain coolant if memory serves me right.
6.4Ls you've got two belts and two tensioners. One is the primary system handling coolant, alternator, power steering. The secondary handling the AC. 3/8" long handle(16") should be the tool you need. If you have a 1/8" steel dowel, or grenade pin as some call them, this can help a lot by holding the tensioner in it's "released" position so you can route the new belt in. Once the new belt is in its as easy as taking a little tension off the pin and sliding it out.
6.7Ls i have no experience changing belts. But i can add that my friend 14 has 150k on the original belt, fathers 16 has 135k original belt, and my 21 at 45k is also original for what thats worth.
