S&S Sunday Project
BroncOh
Tremor of the Month 🏆
Tremor R&D 🧰
Founding Member 📜
Meetup Organizer 🚧
USAF Vet
Glad to have this finished up :D
That looks like a pretty involved install, how long did it take?
About 6 hours after I gathered all the tools and supplies. Wasn't in a rush, just wanted to get it done before the sun went down.
At least you didn’t have to do it twice. Blue o-ring shifted and was crushed and leaked and filled the valley with diesel before then leaking on the ground.
I will always prime the fuel system before I reassemble everything from now on. 😂
At least S&S sent me a new o-ring for free and pretty fast.
Should’ve gotten rid of that ccv too while you had everything apart.
Thought about it but don't want to vent to atmosphere and deal with emissions compliance. Also don't want to mess with a catch can. Edit: see below post
@Himni I just looked and my state doesn't do emissions testing. So, which reroute would you recommend (SPE ?), and is their internal catch can needed? Also, how bad is the oil vapor smell with venting to atmosphere?
Sadly SPE is the best ccv kit. It’s actually really nice and I’d get the internal catch can and the extra length of hose.
I have it routed to just in front of the fuel tank aiming down like a draft tube. I haven’t noticed any smell or smoke unless I’m under the truck by it trying to smell it. I have the catch can and haven’t seen any oil drips yet and don’t know if it’s needed but I got it anyways.
The entire purpose of the pcv is for emissions it has no good purposes for your engine.
I get your point but this isn't actually true. Venting to atmosphere is a form of PCV, just an open instead of closed system. If you don't have any PCV (positive crankcase ventilation) your engine will experience higher oil consumption, blown seals, etc
I’m debating on installing that too but not sure if it’s over my capabilities. I just installed hsm hot and cold pipes with hsm upper fuel filter conversion on Saturday. Also installed spe water fuel drain plug
It isn’t too bad just take your time. Watch PTT Arod’s video on it. Just make sure you use some grease to hold the blue o-ring in place so it doesn’t move and get pinched and leak. Do the ccv reroute too while you have everything apart.
If you have Forscan or a diagnostic tool to clear codes then prime the fuel before putting everything back together and make sure you don’t have any leaks.
Thank you for feedback
Also was wondering if I should wait until out of factory warranty.
I’d do it asap. If something were to happen it without it installed it still wouldn’t be covered by warranty and would cost a whole lot more to get it fixed than if it were installed.
I mean the PCV that is legally mandated and how the truck is stock. not the reroute. PCV and CCV are not the same thing.
