RSI Smart Cap installed.
RSI Smart Cap vs Retrax Tonneau cover and bed rack. Looking for some feedback on both options and there usability. I know the smart cap are BO for awhile. Thanks
Definitely comes down to your bed usage needs. The SmartCaps are an awesome utility. They're fully lockable, super strong, allow you to put a camp kitchen or storage bin in the gullwing windows, allow you to store a RSI table inside on the ceiling, and give you a lot of space in your bed to keep things. They also come in 5 pieces so you can take it apart and store it in the garage if you need to.
Retrax cover and bed rack is a great solution but for a different practice. Retrax cover is also lockable, very sturdy (aluminum slats with the RetraxPro vs polycarbonate on the RetraxOne) and weather resistant, and very easy to use. Having a bed rack on the bed is nice for ease of grabbing things on it as they won't be as tall as the roof of a SmartCap would be. You won't get as much in-bed storage that is safe from the elements as you would with the SmartCap though. With the Retrax covers you can still retain that "truck" look as well.
They're both amazing options but it just depends on what you really want to use your bed for. We've got both if you want to talk more about options and see which you want to think about purchasing. Our RSI caps for the Super Duty are expected to ship at the end of August where as the Retrax covers are in stock now.
So. headed over to the cap dealer today and got my bed rug and Smart Cap installed. Total install was ~$450 but they did a nice job.
Couple of notes:
- There is a center tail light wire under the rear bumper (yellow/blue stripe). They tied into that and brake light on cap works perfectly.
- Hit all the locks when I got home with WD-40 Rust Penetrant (basically light penetrating oil). All are very smooth now.
Couple of small issues:
- Window for bed camera is great. The fact that it is glass and reflects everything is not so great. Will see if I can find some non reflecting film for that.
- Need to add some lights in the bed.
- Smart Cap logo on tailgate is crooked. My OCD will have to deal with that at some point.
View attachment 47253View attachment 47254View attachment 47256View attachment 47257View attachment 47258View attachment 47259
Looks great! How do Lucy and Bella like it back there? Is the seal on the rear window good enough that some AC makes it back there? How is it for keeping dust out? Seems like that positive airpressure vent would only function correctly with a certain speed?
Have just had one dog in so far for rides to the vet. I have a BT thermometer back there now and it gets crazy hot with the FL sun now. The vent does get it cool but even ambient is hot around here. Dust not a huge issue. There is a pretty big gap between the rear window and cap (cap is inset there) so haven’t really tried to get AC back to cap yet.
Once the truck gets back from body shop, I am going to see about adding some insulation panels in the cap. Been looking at material on Amazon today.
I thought there was some kind of boot between the window on the cap to your window on the truck to seal it if you had both windows open? is that not the case? thermometer is a good idea. I do not miss the florida heat or humidity
I’ve had a retrax pro Xr with a yakama rack for awhile and had an ARE topper on my last truck. I can tell you I greatly miss the topper, granted the truck without a topper looks better, but the bed fills up and you run out of room quickly. The retrax does take up some bed space, on a recent vacation I couldnt shut the bed cover because my cooler was slightly too tall. The rack on the bed cover works ok, but a rack on a topper is much better. Personally I wouldn’t go with the rsi unless you are hauling allot of weight and doing that over ruff rutted roads. I think they just don’t fit the lines of the truck well and look odd. If I was going all out on a topper I would go with a caravan camper shell, they are the original extreme topper. I plan on selling my retrax and yakama this fall and getting and ARE with a rack on top.
I got mine from my local dealer. Cap World in Sanford FL. They actually got it in stock in about 3 or 4 weeks. Well before the truck was delivered. I now have the RSI roller rack on order so we can stick canoes or kayaks up there easily.
As for the reflection issue, it has to do with the glass of the window. Get lots of reflections from the sky as well. Angles are just all wrong. I haven’t found a matte film that would work yet. Most of those are not very clear. If could rig up a cover between the window and the camera, I think that would help.
What did help was some lights that I installed in the cap and hooked to the upfitter switches. Work great, especially at night.
What lights did you install to the upfitters? Plan on installing my RSI this weekend. Just picked up the Tremor on Friday
Does the RSI add to the overall height of the truck? It's hard to tell from pictures but it looks like it may be a tad taller than the cab. Need to fit in an garage and curious on height.
Here is a link to the lights I got off Amazon. I also got some zip tie mounts.
- Left lights on workbench with some boards holding them down for a couple of days to flatten them out (they shipped coiled up).
- Shortened some of the wires at the feed end.
- Used the same ground as the cap brake light.
- Replaced the two prong connector for the brake light with four prong connector from O’Reilly. So, just one plug to disconnect.
- Ran feed wire along passenger side to upfitter feed under hood.
Also, drop your spare and look for a yellow and blue wire behind the bumper. This is a CHMSL (center high mounter stop light) wire. Perfect for wiring up the cap brake light.
Lights: https://www.amazon.com/gp/product/B07KXR799K/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Zip tie mounts: https://www.amazon.com/gp/product/B08F77YVYB/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
Without the rack, it is just about the same height as the two GPS(?) antenna bumps. I think the perspective is slightly distorted in the second picture.
  • Like
Reactions: Oak
We sell a TON of Smartcaps and have them in stock more frequently than most. Our Super Duty caps are expected to ship 7/30 if ordered today (or soon).
How far out are y’all on SmartCaps for the Super Duty right now? Hoping to order one within the month.
The RSI Evo Sports (with side windows) are approximately 45-90 days out based on what the manufacturer is telling us. We actually have two Evo Adventures (solid side panels that gullwing open) in stock right now.
Sent you a DM!
Couple of notes:
I am also looking at the RSI Sport SmartCap for my truck which is the same as yours except mine is a F350 Platinum Tremor - had the same desire to have the back camera work. I also noticed you seem to have the factory running boards working - mine has them but they are not connected. I have been posting about that in the another thread. Did yours come connected from the dealer? I bought my truck used and have been struggling to find a way to make them operational.
