Rock LED lights
Can you snap some pics of where you mounted them. I have been thinking about setting up mine the same way and I like the light your setup is putting down. I’ve also thought about mounting one or two under the diamondback cover for a work light.
I have six in the front two on each corner ( room for three) and one on each sides of the winch
4 in the back 2 in front of the rear wheels and 2 behind the rear wheels and one above the license plate I may add two more above the plate as there is plenty of room
^^^^ +1, I'd love to see where you mounted them. The amount of light output is very impressive.
just added a few shots for you
That looks great. I never thought of mounting them behind the air dam. I that seems like a fantastic spot. I'll bet a couple mounted under the hood would be a big help when it's dark out.
@PapaRaptor, which ones did you end up going with? I like the profile and ease of mounting on yours.
I got these, just purchased on Amazon they were reasonable in price, have protective lenses over the LED and are IP 68 Water Proof. unfortunately made in china but most everything is
You need to make your own wiring harness I got some 16 gauge wire with a heavy casing on it. Was 65' long for $44.00, Went to Home Depot and got solder, heat shrink wrap, good electrical tape, and some rubber sealant tape.
rock lites
It was easy and the wires tuck right up. It is steel not aluminum so I painted the holes after drilling them, let it dry before install.
The suppled nuts and bolts are tiny and I fumbled with them a bit. I supplied some small Stainless steel washers for above the steel part on the truck. The housings come with a rubber base plate that you can crush it down and kind of angle the lights.
rock lites
Thank you!
I'm interested in mounting underbody lights to act as scene or work lights. The normal "rock light" locations don't shine very far to the sides. I'm considering magnetically mounting some inexpensive pod lights to the frame and angling them to the front and rear so they'll help when backing up and also show what I'm about to turn in to when moving forwards.
The light pattern would look like an X when viewed from above.
@PapaRaptor: never thought to mount a rear facing light under the tailgate in that plastic piece, that's brilliant.
If you want to magnet mount your lights, these are really nice lights.
Take a look at Lux lighting systems. They make magnetic LED lights in packages in white and with color. Well made and made in USA. I haven't' mounted mine yet but I like that they're magnetic. No drilling. No chance for rust. And you can move them around if you don't get it quite right the first time.
The Lux rock lights were my first choice before I ended up going with the KC lights. I called and emailed them maybe a dozen times trying to ask questions and was never able to get them on the phone or a return call or email back. After so many tries with nothing was afraid to order on the site not knowing if they were still in business or what, or if there was a problem if you would be able to get support so I went to KC.
Good to know. Thanks.
