Retrofitting the Mirror Lights
Lincoln, CA
2022 F250 Lariat Tremor
Hi everyone, wanted to get some advice on the best way to get the Tow Mirror lights looking the way i would like them. I have never been happy with our factory mirror lights and ive tried the smoked aftermarket ones but am also not a huge fan of the look of those either. I saw this not too long ago and its always been a project i wanted to try:
Then Mr. @Shibbyjeep was selling some of his take off parts a few weeks ago and it seemed like a good time to pull the trigger on some take off mirror lights and give it a try! So far i have one of the lights disassembled and now im trying to plan out the painting process. I want these mirror lights to resemble the headlights as closely as possible so my thoughts are i will be leaving the lens clear, while painting the inside of the mirror light a semi-gloss black, while also leaving the amber double bars the stock chrome/white (to resemble the daytime running light white lines in the stock OEM LED headlights. The link above retrofitted some switchback led strips but i think i will be keeping it a bit more basic as i want the lights to remain a constant amber. I havent been able to find 6" just amber led strips and honestly im not even sure how wiring those in would look so just masking off the chrome reflector part of the light is probably my best path forward. Basically my goal is to get close to this (although my mirrors will stay plastic on the bottom):
Now the one thing i think i want to change from the above picture (maybe), is keeping the spotlight functional. I think in this picture it appears it is just painted over. For reference, here is what the inside of the mirror looks like, the 4 red circled areas are 4 amber LEDs that shine through the reflectors for the double bar lights, and then there are 3 LEDs on the circuit board that shine up into the reflectors for the spot light:
Now what im thinking to try and get this to appear as "blacked out" as possible but still maintain spotlight functionality is i can paint the whole thing except for the reflectors in the 2 bars, and the area with the red circles/lines black. So even the green outlined part can be painted because i dont believe any of it is used to reflect the spot light.
1. You think its save to paint the smooth surfaces below the reflectors without sacrificing the spot light? (green outline) I think if i could get those areas black the mirror would look pretty blacked out/clean.
2. Any recommendations on a primer/paint that would work well on this chrome plastic? Thanks in advance everyone!
Update for any of those interested, I think this is what I'm moving forward with as far as taping goes, basically anywhere you see blue will remain chrome and the rest will be black. More to come! Still open to any suggestion on primer/paint that would be the best for this
even though im basically talking to myself at this point I figured I would share an update :) . The paint I used was probably a little too thick however I am pleased with the results. Maybe some minor cleanup to do inside the lens and then I will be throwing in some butyl to help seal it all back up. Once it’s sealed and plugged in I will test the spotlight functionality but I think it should work while still maintaining a very blacked out look!
It does look very impressive! Thanks for sharing it with us and complete with illustrated pics! 👍
I’m no expert with this type of upgrade but I believe they sell a primer/etcher that is used to “scuff” the shiny surfaces to maintain the adhesion of the paint. Some have used the scotch brite type pads on the plastic surfaces as well.
I would think the most important part of this project is to maintain the waterproofness of the seams during reassembly.
Kudos to you for moving forward on this project to personalize your vehicle to your liking! 🏆
Finished up today with some Butyl sealant and padding, although i forgot to get picture of the padding i tried to replicate the foam liner that comes on them from the factory (around the edges). I think the emulate the factory black led headlights much better now as they are painted black on the inside with clear lenses and the "white" bars. All functionality for bars and spotlight is still there!
Looks good!
