RetraxPro XR and BuiltRight Bedside Racks - Does it Fit?
Installed the panels today and it went easier than expected. Each panel needed to be trimmed but I didn’t have to adjust, remove or do anything with the Retrax.
The jigsaw made the cuts easy and precise and once cut we used a QTip to dab on some black Rust-Oleum. From there the impact made removing and reinstalling the bolts a snap. **You will need to use a socket wrench to get the top bolt for the driver side tie down if you have the 5th Wheel electrical prep. The plugs get in the way of the impact.
Now to figure out what else to mount
Thanks for posting. I'll have the same issues.
I have the factory installed Retrax and all four BuiltRight panels installed, but I opted to remove and relocate the four clamps holding cover to bed. Cover remains to slide without issue. Currently have ARB compressor mounted to one small panel and 1 gallon tank on the other small panel...
Excellent. Thanks.
Excellent. Thanks.
I know it’s been awhile, but curious how it’s holding up and if you have any pictures?
Is their any negative to relocating the bed cover clamps? I have the retrax with t slots, clamps on the side of the builtright panels and plan on putting weight on top of the cover.
Been running for 4 years now and zero issues.
