Removing stickers from sun visor?
  • OP 🔹 OP 🔹 FT_Guest3342
  • Start date Start date
A couple of these would go nicely, yeah?
Bingo. That did the trick. I took the plunge and it payed off. Wheeew.
I used the hair dryer method. I had to set it on high heat to get the sticker warm enough to easily peel off. I noticed that the glue is not sticky at all, so it must be heat activated when the sticker is installed. It seems to leave no residue behind, but you can still visibly see where the sticker was. The process seems to slightly change the texture of the cloth and that is what you see.
I should note, that I have had my truck for 5 months and there is some wear and tear on the interior, not much mind you, but a slight bit can show the difference in color where the cloth was protected from the elements by the sticker. You might get a better result from a brand new vehicle.
Just go slow and warm the sticker and it easily peels off, not much force required.
Before:
After:
If he screwed it up I would've bought that visor since I need homelink
Learn something new everyday, never knew these were available.
Good option if you care about selling later. Pretty sure wed have to buy new visors to resell it. Not sure if those have to be there if we (dealer) resell it.
I stumbled across this one, so glad I did! I did this to my Jeep but those had vinyl visors and used alcohol, I'm grabbing the wifes hairdryer and trying it today!
Has anyone tried lightly brushing the cloth after to help blend the area of the sticker yet? I will try it and see if it helps make it less noticeable.
I have tried to brush the cloth. It didn't seem to make much difference. I even tried a small wire brush on it to fluff it up a bit. Same thing. Without the stickers it is much less of an eye sore, so I still think it is worth it.
I watched the video and it appears that maybe the "discoloration" really is just the material being pressed flat in that area when they apply the stickers that causes the visual difference not actually a discoloration to the cloth.
OK, whats the trick on removing the visors, I would rather do them inside on a flat surface!
I don't want to break the plastic cover to get to a screw?
Thanks, four small edge clips holding it to a plastic base so you have to just get the cover edge to pop it off without pulling on the base, then a screw to remove it all.
Came off easily, fabric is a bit loose but I will assume it will tighten back up. Even if it doesn’t I don’t have to stare at the stupid stickers! The photo makes it look much lighter than it really is. It blends in really pretty well.
What i’ve gathered from here and videos, there is no perfect way to remove these stickers. The solution is either
a. peel off with fan and leave the outline , in most cases somewhat discolored or
B. Buy ebay stickers to cover it up
At least to me, both of these solutions look as unattractive as the stickers themselves. The stickers at least are original part and not an after job with a left over signature of an imperfect coverup.
I’d just leave the original no matter how ugly it is.
