SOLD REDUCED! 22' F-35O PLATINUM TREMOR FRNT/REAR CARLI SYSTEM PLUS MUCH MUCH MORE!
Thunder
Tremor Fanatic
NorCal Bay Area
22 F-350 Platinum Tremor Carli
Price Reduced 🤓 2022 Ford F-350 Super Duty Platinum Tremor 6.7 Powerstroke loaded with Panoramic Sunroof, Console Safe, spray bedliner, bed step, and No factory supply issue deletes etc. including over 33K in upgrades/ add ons:
23,8XX miles. PRICED AT 99K
Carli Complete Lift Package Front and Rear.
Carli 22' Ford Super Duty Backcountry 2.0 (4.5"/5.5" Lift) Suspension System:
  • Sway Bar Options: Torsion Sway Bar - Includes Sway Bar End Link Kit, 4.5" & 5.5" Lifts (CS-FTSB-4.5-17)
  • Rear Leaf Spring Options: Ford 2017 Full Progressive Leaf Packs For 4.5" Systems (CS-FFSP-17)
  • Long Travel Airbags: Long Travel Air Bag System, 2017+ Super Duty - 4.0" Axle Tube (CS-FLTB-17-4.0)
  • Fabricated Radius Arm Option: Fabricated Radius Arms, 4.5" Lift (CS-FARA-45-05)
  • High Mount Steering Stabilizer: High Mount Steering Stabilizer (CS-FHMSS-17)
  • Low Mount Steering Stabilizer: NO Low Mount Steering Stabilizer (NO)
  • Including Professional Installation with 3 progressive shop rechecks /retorque to ensure system integrity.
  • Airlift 74000 EZ 2.0 wireless Heavy-Duty on-board air system for your Carli Long Travel Bags- W/ Bluetooth & Remote controller, dual path air spring controller.
10,783 + Install 1700 - 13,500 value
3M Dark Platinum full body wrap- plus tastefully done, partial chrome delete including custom Platinum Badge. Wrapped New so whenever you decide to remove you will have a factory new Carbonize Grey paint job with no defects. 4500$
Ceramic Window Tint all around including windshield and panoramic sunroof. 750+
Choose Your Tire and Wheel package of your choice included with Truck:
1) Method MR704HD 17X9 with BEADGRIP technology, for full weight/tow/pressure capacities. Additional Baja Champion Center Caps and plus Original Method Center Caps available. With Toyo 37x13.5 tires mounted/balanced including all Ford TPMS sensors, 12 ply F full capacity for your HD needs. Black Spline Lug Kit.
Approx 9500 miles on them. No scrubs/scrapes or defects. Great like new Condition. 4700$ + value
OR choose! -
TIS 554BM 22X10 -19 554BM
W/Nitto Ridge Grapplers 37x12.5 12 Ply F
Approx 11K miles on them. No scrubs/scrapes or defects plus all Ford TPMS sensors. Black Spline Lug Kit Great like new Condition. 4700$ + value
Do Have to have BOTH sets? Make me an offer for all of them.
AMP XL Steps (Lower step drop for lifted truck) with Added bypass switch to keep your steps down or up whenever you want even at full speed. Added OBD portal so you have full access to your OBD port without needing to disengage your steps. 2500$ + install value.
RETRAX POWERTRAXPRO XR TONNEAU COVER (electronic w/remote control open/close, LED bed light and T-slot bed rail system to build accessories on top of bed if you wish)
$2,949.99 + tax and install value.
Description​
  • The integrated Trax Rail System works well with most T-slot rack accessories from Rhino Rack, Yakima, Thule, and many more.
  • Utilizing a remote keyfob, this retractable pickup bed cover opens and closes at the touch of a button. Wireless operation allows it to easily open and close, and an electromagnetic brake allows it to lock in any position along the rail.
  • The patented low-profile design incorporates a front cover that is flush with the truck bed cover, which streamlines the overall appearance and provides a firm, dependable seal to help to keep the truck bed dry.
  • Sealed ball-bearing rollers are mounted onto each section. This allows the PowertraxPRO XR to open and close easily with one hand, without the need for pull straps, Velcro, snaps or springs. Ball-bearings provide smooth operation, preventing the cover from binding when opening or closing.
  • Constructed from heavy-duty aluminum slats that are engineered to retract without trapping dust, wear out or freeze.
  • 3 year from purchase full warranty, then a limited lifetime warranty after the 3 years expire
The XR Series combines the PowertraxPRO MX with the integrated Trax Rail System that allows for unique and personal customization above your tonneau cover. The PowertraxPRO XR electric retractable truck bed cover combines industrial strength aluminum construction with an incredibly resilient matte finish.
The XR Series optimizes cargo capacity with the cover open or closed, providing the ultimate versatility in cargo management. The Trax Rail System will work with most T-slot accessories from Rhino Rack, Yakima, Thule, and many more offering endless possibilities. Check out our Accessory Compatibility Chart to find the accessory that is best for you! (Accessories Sold Separately)
Pairing the Trax Rail System with accessories offers double the cargo capacity. This unique technology frees up the hitch with the ability to mount bikes, coolers, outdoor gear and more on top of the bed cover by combining the Trax Rail system with the t-slot accessories.
Distributed closed cover Weight Rating of 500lbs.
Professional Alarm System —
Compustar PRO T13
Pro 2-Way RFX Bundle w/ LTE Drone Mobile Module
With remote start and keypad for manual disable and drive option with Hide A key drone mobile module in console safe. 2k value.
Full Ceramic Coating interior and exterior. 1K value
Additional Value Add Ons included:
Weather Tech Front and Rear Mats
Custom black Tremor Badges
Front Ford big blue Oval Replaced with new Black/Grey factory Oval.
Sound System Upgrade:
Front Door Alpine R2-S69 6X9 speakers and tweeters.
Rear 10” Kicker 46HS1 Sub and Amp.
750$ value plus installation
All Totaling more than 33K+ add Ons.
But wait... there’s more!...
- Add Ons available Should you choose them at additional, but reduced costs to you, your choice.
1) 6 YR / 150k mile Ford Premium Care FACTORY EXTENDED WARRANTY, WITH Enhanced Rental Option included! Don’t get left out cold without that enhanced covered rental. available at a reduced cost to you.
2) Class 3 Platinum Ford Maintenace Package included at reduced cost to you if you.
——Interested? Let’s Talk Soon ASAP. Message me. Not interested in arguing my costs or values or opinions here on here on the post, your all professionals and know what these things cost. Appreciate It.
Oh yeah, why am i selling? No Issues with the Rig, just have another urgent situation to prepare for that recently reared its head. I’m in Northern California Thanks Fellers.
23,8XX miles. PRICED AT 105K. WHAT DO I GET FOR 105K???
OR choose! -
Description​
Compustar PRO T13
1) 5 YR / 150k mile Ford Premium Care FACTORY EXTENDED WARRANTY, WITH Enhanced Rental Option included! Don’t get left out cold without that enhanced covered rental. available at a reduced cost to you.
Oh yeah, why am i selling? No Issues with the Rig, just have another urgent situation to prepare for that recently reared its head. Thanks Fellers.
Oh Yeah I am Located in Nor Cal Bay Area.
OR choose! -
Description​
Compustar PRO T13
6 Year 150k Mile Ford Premium Care Ext Warranty with the Enhanced Rental Option is available for this Rig. Mistake on original post I put 5 year. It’s a 6 year.
You can edit your post.
OR choose! -
Description​
Compustar PRO T13
REDUCED PRICE BUMP!
Have you tried FB groups? There are more eyes on SD trucks there. Yeah, you will get some rough comments with it, but the exposure is better than here and might help with finding that «one guy» looking to for a fully built out last gen truck to be had.
I have not in my area , but my buddy did for me in a different are, I don’t have FB and trying hard not to. But I might just do it for the reasons you said !
OR choose! -
Description​
Compustar PRO T13
Be prepared for some very rough comments if you do use FB marketplace. I'm in the bay area and the good thing you have going for you is there's a shortage for clean used super dutys. I'd be interested if it was more stock, but you need that unicorn buyer whos looking for all the customizations you've done to be willing to pony up the premium.
OR choose! -
Description​
Compustar PRO T13
