Rear window rattle
Bryantbjb
Tremor Fanatic
Salem, Oregon
2021 Ford Tremor
2020 Ford Explorer ST
Hi All,
With the great weather I’ve been opening the sunroof and rear window more. Has anyone experienced the rear slider window rattle when opened? I’ve looked all over and can’t figure it out. The second I crack the rear window there becomes a pronounced rattle. No rattle when closed. I’m stumped.
Is it just me?
Thanks.
It might be the cable that operates the slider. Shortly after I purchased my truck I developed a similar noise. I discovered that one of the clips that hold the cable in place had not been installed at the factory and was hanging from the cable. It's a pain in the ass to get to, but fixed the problem.
Just one more suggestion, the noise is not coming from outside the truck, such as the bed or underneath the truck? Maybe something loose that way. If it is a constant noise and you can easily duplicate, I would just take it to the dealer and have them figure it out.
Mystery solved. It is my bed cover rattling at higher speeds. It’s the GatorTrax roll cover. I really like it, however, at higher speeds and with wind, the middle center moves up and down a bit causing the rattle. Kudos to my wife who spotted it.
It's amazing how quiet the cab is on these trucks with the windows closed. With the slider closed all was peaceful quiet driving down the road. I noticed shortly after getting my truck, when I opened the slider I could hear a very noticeable rattle in the back. It turned out to be one of the factory ramps rattling in the holder bracket. They have a lever bolt that is suppose to lock them tight to the mounting bracket. One of the bolts was cross threaded and only screwed in about one turn. This allowed the ramp to rattle. I had to remove the bolt, chase the threads with an M12 tap and then thread the lever bolt in tight to the ramp. Problem solved. ;) ?
Agreed. At first I did not believe her. I was positive it was the rear window or something like that. She took video and boom, it was the cover. Now reaching out to Gator to see if there is a solution.
