Rear mount distribution block
WA Roofing Services
21 Platty Tremor 350
Hey guys,
Been a wiring guy for a while now, and been obsessing about adding things to the truck, but also keeping the wiring clean!
Adding an air system next week, just added a wireless bag controller w/ 7500 bags, and whatever else I may put in the rear of the truck got me thinking a bit....
Instead of running power and ground wires to and from the engine bay to the battery individually, I got a distribution block.
After some research, I came across one on Amazon for under $30. I like it alot.
TIYANG Camper Car Audio Distribution Fuse Block with Ground Mini ANL Fuse Box Distribution Block 0/4ga 4 Way Fuses Holder 30A 60A 80Amp Red LED Indica https://www.amazon.com/dp/B078SCQJNM/ref=cm_sw_r_apanp_YjsjqkYCo9N22
So i ran a 0/1 GA power wire from passenger side battery to the rear of the truck along the passenger side. Wrapped it in conduit for protection, and got some heat shielding for certain areas along the way.
Ran another loom with a 6ga ground wire and my relay wires. Wrapped that in conduit and heat shield as well. Drilled a few small holes in the frame along the way and put some Christmas tree zip-tie mounts to hold it steady.
Ground wire hooks right up to the battery, and the other wires hook right up to their upfitters.
I ended up mounting the distribution block to the underside of my 74000ez kit so it's easy to replace fuses on, and remove if needed.
A couple spots it could be mounted above the spare tire for sure!
Distribution block is sweet. Has quite a few spots for power outgoing, and even has the ground locations in the same block.
Now i can pull power for a few extra things directly from the back of the truck, and only need to run one wire to an upfitter if needed!
Very nice setup!
Though I'm curious: why the significantly smaller ground wire? Doesn't it need to carry the same current as the positive wire and should be the same size? Do you also have a ground direct to the chassis to alleviate that need?
Though if the latter, then you wouldn't need the ground wire at all, right?
Very nice setup!
Thanks!
I went overkill on the power wire, there's not much I'm going to hook up that'll even need that size wire, but its for potential.
and the ground wire in a sense is useless because things can ground anywhere, really. I just wanted the few items I do/ will have to have a solid ground right to the battery so I could avoid drilling holes in the frame for ground.
For my plans, the 6ga is enough for all my plans.
Thanks!
Gotcha. Guess I find it strange you ran distinctly sized wires. If you want the utilize the potential, won't you need to re-run your ground?
By the way, I'm asking questions as I'm working towards quite a significant electrical install on my truck and want to make sure I'm not missing something in my own planning. :) In my plans I'll be running 2/0 from the battery to the back seat for positive, then 2/0 to the frame just below the cab for the ground.
I put my plans for the bed mounted 2,000 Watt Inverter and Andersen Plug on hold for awhile. It requires 0000 wiring, like a $1,000 in wiring bs, I've gotta save up that .. This past year I seem to be hemorrhaging cash every time I leave the house. :mad::mad::mad:
  • Like
Reactions: ccw
This is great. Have done this on my last two trucks. Sure makes life easier when you need to run a circuit. I used a Blue Sea version. Nice job.
