Just finished my install. I think the end links should be a bit longer, as even with the minimum thread insertion (7 threads) I can't get the sway bar level. This may be an advantage of the other kit if the links are longer.
I also had a weird issue that one of the 10mm bolts had a 13mm head while the other three were 15mm.
I did call tech support to find out the minimum thread insertion and couldn't believe how fast I was able to get through to talk to tech support.
