Is the difference gas (5200) vs. diesel (5600) models?
Anyone use SumoSprings to correct this?
I think the front SumoSprings are in full contact even without the extra weight of the bumper and don't really limit the "already limited up-travel" of our stock trucks. I've run rears (not fronts) so this is just theory...but my suspicion is they may restore the front end height and have a more progressive bottoming out.I guess you could depending on the amount of weight added. If I follow the idea correctly you are using the Sumo as a "on contact bump stop", thus limiting the downward movement of the added weight and potentially limiting overall suspension travel.![]()
Ah, ok. I must have mis read a prior post that it was 200 lbs for the bumper.Whats the summit weight? 243-300lbs on the box. Its noticeably raked. No issues or anything drive wise previously. There is definitely a difference now in steering, actually vibrates if backing out and turning not rolling. Now if you can actually stand on the tow hooks and work on it that is quite impressive lol
